查看: 183|回复: 18
What does the air system do for my truck? I never really understood it .
 楼主| 发表于 2019-12-16 02:40:04 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-12-16 03:27:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"The air system releases air into the cabin so you don’t lose consciousness at higher altitudes in the mountains. Hope this helps. 👍","replyToPid":0}
发表于 2019-12-16 03:06:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"I agree with hotshot, not trying to put you down but that’s really a HUGE if not one of the BIGGEST PARTs of your Obtaining your CDL. ","replyToPid":0}
发表于 2019-12-16 03:03:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"with all due respect but if you have to ask this question, then you shouldn't be in a truck. good luck to you👍👍","replyToPid":0}
发表于 2019-12-16 06:45:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s for inflatable companions ","replyToPid":0}
发表于 2019-12-16 04:38:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"I shouldve known this was a troll when I came across the first question about fuel. Smh go play in traffic","replyToPid":0}
发表于 2019-12-16 03:24:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Fake!","replyToPid":0}
发表于 2019-12-16 05:03:32 来自手机 | 显示全部楼层
255590 发表于 2019-12-15 20:38:27 I shouldve known this was a troll when I came across the first question about fuel. Smh go play in traffic
","text":"Seriously tho this dude is either that naive or just 2 bricks short of a full load 🤦🏻‍♂️.... you understand me what im trying to say here honey 🍯 ","replyToPid":282802}
发表于 2019-12-16 08:42:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"(Without air, u can't make a dollar.)","replyToPid":0}
发表于 2019-12-16 11:07:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Fake as flying frogs","replyToPid":0}
 楼主| 发表于 2019-12-16 03:33:32 来自手机 | 显示全部楼层
发表于 2019-12-16 03:10:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Applies brakes and releases your parking brakes 🙄","replyToPid":0}
 楼主| 发表于 2019-12-16 03:33:41 来自手机 | 显示全部楼层
 楼主| 发表于 2019-12-16 03:33:54 来自手机 | 显示全部楼层
 楼主| 发表于 2019-12-16 03:34:06 来自手机 | 显示全部楼层
GMT+8, 2026-2-16 17:16 , Processed in 0.068268 second(s), 24 queries .
