查看: 385|回复: 18
Does this really happen?
 楼主| 发表于 2019-12-15 05:02:49 来自手机 | 显示全部楼层 |阅读模式
{"text":"We've all heard the campfire scary stories about checking your fifth wheel every day before driving because some Richard will pull the pin while you're inside dropping a deuce. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-15 10:00:48 来自手机 | 显示全部楼层
724453 发表于 2019-12-15 00:36:02 I have trust issues, I always check my that my 5th wheel is still locked, the trailer seal is still intact and the tandem axle pins are out if the truck is ever out of my sight
","text":"I'd rather check then not and become a swift","replyToPid":282134}
回复 支持 7 反对 1
发表于 2019-12-15 08:36:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have trust issues, I always check my that my 5th wheel is still locked, the trailer seal is still intact and the tandem axle pins are out if the truck is ever out of my sight","replyToPid":0}
发表于 2019-12-15 05:15:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's part of pre-trip and just makes sense","replyToPid":0}
发表于 2019-12-15 07:40:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"it does happen but not often","replyToPid":0}
发表于 2019-12-23 16:18:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m sure drivers who want revenge on someone they saw on the road or at their company. So yes it does happen or someone who had a bad day that wants to make others worse to make them feel better","replyToPid":0}
发表于 2019-12-21 13:06:21 来自手机 | 显示全部楼层
706454 发表于 2019-12-15 13:27:03 The new one is someone will stick something in your supply line while your away from your truck.\nIt causes the lack of trailer braking power.
","text":"We used to prank our buddies by putting a quarter in the red gladhand, then hiding to watch their reaction. 😉","replyToPid":282460}
发表于 2019-12-18 01:29:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you walk away from your truck, put your eyes on that pin when you return. Never know how many former drivers hate your company--but, will ruin your day to spite the company.","replyToPid":0}
发表于 2019-12-18 01:12:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"trust nobody!!!!","replyToPid":0}
 楼主| 发表于 2019-12-16 01:57:13 来自手机 | 显示全部楼层
103619 发表于 2019-12-15 02:00:48 I'd rather check then not and become a swift
","text":"Me too","replyToPid":282247}
发表于 2019-12-16 21:15:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"I pulled someone’s pin a long time ago as the driver cut me off and then pissed everyone off at the truck stop so when he parked at the pump and went in a pulled his pin and watched that trailer drop as I was leaving the lot. ","replyToPid":0}
发表于 2019-12-15 12:44:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm a Swift driver and I always check mine.","replyToPid":0}
发表于 2019-12-15 21:27:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"The new one is someone will stick something in your supply line while your away from your truck.\nIt causes the lack of trailer braking power.","replyToPid":0}
 楼主| 发表于 2019-12-16 01:56:45 来自手机 | 显示全部楼层
464157 发表于 2019-12-14 21:15:10 it's part of pre-trip and just makes sense
","text":"Can't deny that tho","replyToPid":281958}
 楼主| 发表于 2019-12-16 01:56:56 来自手机 | 显示全部楼层
827745 发表于 2019-12-14 23:40:34 it does happen but not often
","text":"Gotcha","replyToPid":282097}
 楼主| 发表于 2019-12-16 01:57:06 来自手机 | 显示全部楼层
","text":"👌","replyToPid":282134}
GMT+8, 2026-4-17 10:13 , Processed in 0.108168 second(s), 24 queries .
