查看: 125|回复: 11
Anyone running a Freightliner Coronado?
 楼主| 发表于 2019-12-14 09:11:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"I've been kind of eyeballing these a little bit I don't mind the looks of them and I ran a cascadia 9 years ago and had good luck with it. \njust wondering what you think of it and are there known problems or have you had any?  \nI'm looking for something that is used preferably under 300k but I have had nothing but problems with Kenworth so I was thinking about going this route.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-14 09:12:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Trump keeps WINNING","replyToPid":0}
 楼主| 发表于 2019-12-14 09:16:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"we would all be screwed if he  didn't","replyToPid":281381}
发表于 2019-12-19 15:04:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes got a real nice Coronado for saleill give you some pics and info in the morning","replyToPid":0}
发表于 2019-12-14 10:01:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Got the Coronado and Coronado SD (a bit boxy on looks, SD = \"Severe Duty\") with set forward and set back variants for where the steer axle sits.  Decent truck normally working a DD15 engine.  The problems I experienced were early production DD15 problems with injector seals being too soft and leaking, replaced with a harder rubber version.  I think there is a tendency for the upper cab cap to leak along the seal (general freightshaker problem), but I haven't experienced it myself.  I tended to run the front axle a bit heavy, but it was rated 13k lbs with 16 ply steer tires rated a bit more.","replyToPid":0}
发表于 2019-12-14 23:26:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Had a 2007. Ran it to 1.4 million. Very good truck. ","replyToPid":0}
发表于 2019-12-14 10:22:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Trash","replyToPid":0}
发表于 2019-12-14 13:45:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Following the Trump wagon, all the way to impeachment. 😂","replyToPid":281381}
 楼主| 发表于 2019-12-19 14:16:28 来自手机 | 显示全部楼层
670777 发表于 2019-12-14 15:26:15 Had a 2007. Ran it to 1.4 million. Very good truck.
","text":"what engine/transmission did you have in yours?","replyToPid":281716}
发表于 2019-12-19 15:01:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes I run one","replyToPid":0}
GMT+8, 2026-2-17 01:22 , Processed in 0.085073 second(s), 24 queries .
