查看: 231|回复: 12
using a CB
 楼主| 发表于 2019-12-14 05:39:08 来自手机 | 显示全部楼层 |阅读模式
{"text":"I drive a company truck but never use the CB. What channel is a more common channel so I could at least listen in","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-14 07:04:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"channel 100.\nHoward is on between 6-10","replyToPid":0}
发表于 2019-12-14 06:42:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"19","replyToPid":0}
发表于 2019-12-14 05:46:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"channel 19","replyToPid":0}
 楼主| 发表于 2019-12-15 03:14:55 来自手机 | 显示全部楼层
646676 发表于 2019-12-14 13:06:11 21 if on I-10 west of El Paso. well, it used to be.
","text":"I'm getting plugged in with all the info now, thank you","replyToPid":281668}
发表于 2019-12-14 21:06:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"21 if on I-10 west of El Paso. well, it used to be.","replyToPid":0}
 楼主| 发表于 2019-12-14 05:47:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"thanks","replyToPid":281240}
发表于 2019-12-14 07:58:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Things sure have changed. Channel 17 on 5 between the grapevine and the bay.","replyToPid":0}
 楼主| 发表于 2019-12-14 08:44:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank you","replyToPid":281267}
 楼主| 发表于 2019-12-14 08:44:42 来自手机 | 显示全部楼层
686228 发表于 2019-12-13 23:04:30 channel 100.\nHoward is on between 6-10
","text":"cool, good to know. thank you","replyToPid":281281}
 楼主| 发表于 2019-12-14 08:46:36 来自手机 | 显示全部楼层
756380 发表于 2019-12-13 23:58:54 Things sure have changed. Channel 17 on 5 between the grapevine and the bay.
","text":"That would be real helpful since I'm from California but not picking up much loads during this time a season. Thank you.","replyToPid":281330}
发表于 2019-12-14 09:33:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"just keep your ear buds in not missing much on the CB other them bitchy billy big riggers complaining about someone in the middle Lane holding them up there a real trucker everyone else is steering wheel holders .... basically over and over everyday","replyToPid":0}
GMT+8, 2026-2-16 14:04 , Processed in 0.073759 second(s), 24 queries .
