查看: 101|回复: 1
Yesterday in North Dakota
 楼主| 发表于 2019-12-13 15:10:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2220.0,\"name\":\"\",\"url\":\"\",\"width\":1080.0},{\"description\":\"\",\"height\":1134.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0},{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1134.0}]","canComment":true,"externalShare":false}
 楼主| 发表于 2019-12-13 22:02:56 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Yeah, man the cold weather up there is on a whole another level! Get you that thaw out emergency adedtive if you have to and put  alcohol or anti freeze in your air lines don't forget to put the owes anti gel in your fuel and hit the cruse button when you idle it will save you headaches."}
GMT+8, 2026-2-16 11:05 , Processed in 0.052876 second(s), 23 queries .
