查看: 119|回复: 5
Tire blew out on I-30
 楼主| 发表于 2019-12-13 12:16:42 来自手机 | 显示全部楼层 |阅读模式
{"text":"I had this tire changed like 10 days ago and it had tread on it this morning and if you look at the tread now, it’s completely gone... ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1102.0,\"name\":\"\",\"url\":\"\",\"width\":826.0},{\"description\":\"\",\"height\":1102.0,\"name\":\"\",\"url\":\"\",\"width\":826.0}]","canComment":true,"externalShare":false}
发表于 2019-12-29 13:12:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Too much or too little pressure probably, I always recheck pressure after i get a tire replaced, sometimes they'll put too much air at the shops. ","replyToPid":0}
发表于 2019-12-30 07:26:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"was it recap \nsome make recaps from too old of tire","replyToPid":0}
 楼主| 发表于 2019-12-31 02:42:37 来自手机 | 显示全部楼层
714322 发表于 2019-12-29 23:26:17 was it recap \nsome make recaps from too old of tire
","text":"It was not","replyToPid":292988}
发表于 2020-1-3 01:57:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"I had a Michelin virgin steer come apart one time and then a drive tire with 80% tread lost it’s tread on a virgin wide single. Very odd what tires will do sometimes but it’s all part of the game. If you’re out here long enough you’ll see crazy stuff","replyToPid":0}
发表于 2020-1-7 06:56:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"done lost your recap.","replyToPid":0}
GMT+8, 2026-4-17 15:57 , Processed in 0.088906 second(s), 23 queries .
