查看: 541|回复: 13
Good question, what is this?
 楼主| 发表于 2019-12-13 10:21:30 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":960.0,\"name\":\"\",\"url\":\"\",\"width\":720.0}]","canComment":true,"externalShare":false}
发表于 2020-3-12 00:55:07 来自手机 | 显示全部楼层
518050 发表于 2019-12-14 20:19:55 A height scanner?? You got me, idk
","text":"It’s the new mandatory emissions filter system ","replyToPid":281884}
发表于 2021-6-28 21:28:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hillbilly scanner for UFOs ","replyToPid":0}
发表于 2020-3-12 07:27:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's where the lube is stored so when I sit on top it doesn't hurt as much","replyToPid":0}
发表于 2020-3-12 01:09:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Looks like one of those sirens for tsunami alerts ","replyToPid":0}
发表于 2020-3-12 07:46:39 来自手机 | 显示全部楼层
518050 发表于 2020-03-11 22:58:02 Ain’t gonna lie I didn’t even realize it was on top of the smoke stacks. I thought the truck was going between two poles with that on top
","text":"There made of plastic I’m surprised they can take the heat ","replyToPid":342245}
发表于 2021-4-14 23:27:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Silencers ","replyToPid":0}
发表于 2021-4-15 09:22:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://drive.google.com/file/d/1PG35YOLrFcUX6CwP51OzODweSmQVUGoN/view?usp=drivesdk","replyToPid":0}
发表于 2021-1-14 15:20:44 来自手机 | 显示全部楼层
765258 发表于 2020-03-11 16:55:07 It’s the new mandatory emissions filter system
","text":"close like a oil refinery that has the flame outs for fuel vapers or if someone really messes up so they vent off fuels and fumes in a hurry makes a giant flame up to 100ft tall or more.","replyToPid":342118}
发表于 2019-12-15 04:19:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"A height scanner?? You got me, idk","replyToPid":0}
发表于 2020-3-12 06:58:02 来自手机 | 显示全部楼层
","text":"Ain’t gonna lie I didn’t even realize it was on top of the smoke stacks. I thought the truck was going between two poles with that on top","replyToPid":342118}
发表于 2020-3-13 05:06:48 来自手机 | 显示全部楼层
765258 发表于 2020-03-11 23:46:39 There made of plastic I’m surprised they can take the heat
","text":"I’m sure something melts of off the inside and then falls inside the base and melts to the bottoms of the stack causing a block. I would be considerate and cautious before putting this on my truck. Just saying","replyToPid":342266}
GMT+8, 2026-4-16 10:10 , Processed in 0.115998 second(s), 25 queries .
