查看: 251|回复: 11
Heya truckers! Are trucks allowed on the Manhattan Bridge?
 楼主| 发表于 2019-12-13 09:13:55 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-12-13 22:30:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Heya Driver,  buy a 2020 Motor Carrier road Atlas and learn to use it. \n\nCHEERS!!!","replyToPid":0}
回复 支持 8 反对 1
发表于 2019-12-14 10:09:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"That region doesn't exist on my map for a reason.  No NY HUT sticker for me.","replyToPid":0}
发表于 2019-12-14 00:08:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"yeah you're good to go","replyToPid":0}
发表于 2019-12-13 22:56:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Drive there and find out!","replyToPid":0}
发表于 2019-12-14 00:57:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"just drive on it and find out!!! if you cant and get caught play dumb","replyToPid":0}
发表于 2019-12-14 01:36:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"OK Millenial, ask SIRI!!  😄","replyToPid":0}
发表于 2019-12-14 03:06:47 来自手机 | 显示全部楼层
836417 发表于 2019-12-13 14:36:21 or a good truck gps. i prefer garmin. but nally aint bad either
","text":"What’s a nally?","replyToPid":281026}
发表于 2019-12-14 04:32:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes, any interstate is designated for class 8 tractor trailers with an 80,000 gross weight and 13’6” height. New York marks their over passes at least a foot under so if you see a 12’6” bridge, you may fit under. Just approach and stop and pull to the side if possible and look before attempting. Call local police if you get in trouble. Now that being said, the George Washington bridge is very expensive and they probably want  cash. Bring at least 300$ cash to get in and out of NYC, probably 500 to be safe. Good luck ","replyToPid":0}
发表于 2019-12-14 04:36:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Oh never mind, Manhattan bridge is actually the name. Looks like it is safe for big trucks. I’ll post a pic of map if possible ","replyToPid":0}
发表于 2019-12-14 04:39:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Can’t figure out how to upload on here but Williamsburg bridge is same color on map and look passable as well as the Brooklyn bridge. Brooklyn bridge has an orange line so it’s probably bigger and more used for big trucks ","replyToPid":0}
GMT+8, 2026-4-16 14:14 , Processed in 0.094764 second(s), 24 queries .
