查看: 69|回复: 3
Have you ever been so sleepy that you cannot think clearly anymore?
 楼主| 发表于 2019-12-12 05:45:07 来自手机 | 显示全部楼层 |阅读模式
{"text":"lol. I have and now I don't want to do it again.  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-12 22:06:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Driving 12 12s help you go to bed a frequented time, which helps you go to sleep normal.  Oxygen and food besides sleep help with awake.  Also trucker mantra... (ie you have to make lane change. You say   “Signal” you turn on signal, “mirror” you check mirror, “watch the road” you watch road, “over the shoulder” you check mirror again, “ if it’s clear ....” depending if lane is clear you do accordingly - if clear “go”","replyToPid":0}
发表于 2019-12-13 03:46:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"yea so tired to the point i had to get out and touch the road but i no longer run like that anymore sleep is very important and the loaf gets there when i do f**k dispatched times!!!!!","replyToPid":0}
发表于 2019-12-13 05:25:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"I usually stop thinking and I get cross eyed. ","replyToPid":0}
GMT+8, 2026-2-15 20:47 , Processed in 0.054962 second(s), 23 queries .
