查看: 309|回复: 12
Off to a bad start.
 楼主| 发表于 2019-12-12 05:18:06 来自手机 | 显示全部楼层 |阅读模式
{"text":"After coming back from my 34-hour reset, I've backed into a dock railing, and now just clipped another tractor's passenger-side mirror while backing into a spot at the Pilot/Flying J I'm at.😳\n\nLike what the hell?! I know I'm a rookie, but this is ridiculous. 😩\n\n(I'd attached the railing photo but this app doesn't support the newer HEIC format my Samsung Note10+ shoots in.)","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-12 06:01:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"cool story bro.","replyToPid":0}
回复 支持 6 反对 0
发表于 2019-12-12 18:54:47 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Keep up the good work. Also, quit your job. If you can’t get out and fuking look then we don’t need your dumb a$$ out here."}
回复 支持 0 反对 3
发表于 2019-12-12 21:44:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"maybe you should just stop for another day.","replyToPid":0}
发表于 2019-12-12 16:52:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"GOAL ","replyToPid":0}
发表于 2019-12-12 11:24:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m still new to and I’m still trying get my backing down. Good luck out there. ","replyToPid":0}
发表于 2019-12-12 06:03:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"😂","replyToPid":279671}
发表于 2019-12-12 14:54:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"It happens and it can be discouraging just take your time ive experienced this too and have had it happen to me as well","replyToPid":0}
 楼主| 发表于 2019-12-12 20:58:49 来自手机 | 显示全部楼层
861197 发表于 2019-12-12 10:54:47 Keep up the good work. Also, quit your job. If you can’t get out and fuking look then we don’t need your dumb a$$ out here.
","text":"That's probably what I'm irritated the most about, I got out three times.","replyToPid":280157}
发表于 2019-12-13 18:51:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take your time and get out of your truck and look what’s around you how close your getting to something hitting other trucks cost money and down time ","replyToPid":0}
GMT+8, 2026-4-19 08:17 , Processed in 0.088525 second(s), 24 queries .
