查看: 456|回复: 36
When to call it a day for snow/bad weather?
 楼主| 发表于 2019-12-12 03:21:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"What do y'all look for when you decide the road conditions are too bad to continue driving?  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-12 04:28:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"when you get tired after 4-5 hours and made a hundred miles, feel the truck slipping in your lane, no one else is on the road.","replyToPid":0}
发表于 2019-12-12 12:04:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Call it the day once you slip off the road and reck the truck.","replyToPid":0}
发表于 2019-12-12 03:55:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just when you’ve had enough ","replyToPid":0}
发表于 2019-12-12 10:37:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"wait.... a snow day!??? we get those for 5 months in Canada.... the world doesn't stop. so if you do. get outta the way","replyToPid":0}
发表于 2019-12-12 06:16:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"fake","replyToPid":0}
发表于 2019-12-12 04:41:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"when your undies get soiled","replyToPid":0}
发表于 2019-12-12 06:31:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"It's not necessarily the roads that bother me, it's the idiots I'm Sharing the road with that only know two speeds, stop/go.\nDuring inclement weather I adjust my speed to match the conditions,  and now I'll shut up and let all the \"Super truckers\" chime in.","replyToPid":0}
发表于 2019-12-12 06:00:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Anytime you don’t feel safe","replyToPid":0}
发表于 2019-12-12 04:44:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"when the snow starts sticking and getting 2 or 3 inches thick on the road it's time to call it a day , after that it gets dangerous","replyToPid":0}
发表于 2019-12-12 05:45:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"If the road crews are staying head of it with plows and salt, you should be fine. If it’s building up or hard to see, call it like cookie said. Assuming your not hauling life saving medical stuff or a fema load that is. ","replyToPid":0}
发表于 2019-12-12 08:24:17 来自手机 | 显示全部楼层
875036 发表于 2019-12-11 23:09:25 Calling it a day is illegal now. Has been for some time
","text":"Yes. I believe the politically correct term is “uninterrupted semi bi-nocturnal chronological episode”","replyToPid":279743}
GMT+8, 2026-4-17 10:13 , Processed in 0.131498 second(s), 24 queries .
