查看: 266|回复: 19
first time driving in snow
 楼主| 发表于 2019-12-11 20:20:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"Anything I should know about driving in this white crap? I am in Buffalo NY and they are saying snow with 40mph winds so any help is appreciated at this point. The only help anyone has given me is to go slow.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-11 21:52:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t listen to anyone that says you should run your engine brake. They’re dead wrong. Like @sean1970 said no engine brake, no cruise. If it gets too much PARK YOUR TRUCK! \nEverything in that trailer is insured and can be replaced. You may be insured but I’ll bet your family can’t replace you. \nNever let ANYONE guilt you into driving when you don’t feel comfortable or safe. It’s easy for others to say something. They aren’t behind that wheel. ","replyToPid":0}
回复 支持 14 反对 0
发表于 2019-12-11 21:11:42 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"No engine brakes, no cruise control and do not do anything abrupt (I.E. whipping the steering wheel, stabbing the brakes, etc)\n\nAnd do not drive beyond your comfort zone.  There is no shame in being passed by our super trucker buddies."}
回复 支持 9 反对 0
发表于 2019-12-11 22:18:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes you must go 75 on the highway","replyToPid":0}
回复 支持 4 反对 3
发表于 2019-12-11 22:01:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"40 mph winds? if you're not rolling over 65k I would park it snow usually isn't too bad during the day because traffic tends to keep the road clear just keep your rpms as low as possible so you don't spin and try to keep the wheels going rather than stopping, but wind is tricky. Drive safe","replyToPid":0}
回复 支持 6 反对 0
发表于 2019-12-11 20:51:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Slow and easy is good. Give yourself extra time to slow down to stop, increasing your following distance for you have time to stop. ","replyToPid":0}
发表于 2019-12-11 21:06:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Either slow-rolling or shut down.","replyToPid":0}
发表于 2019-12-16 02:22:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have no problem with wind or snow, but both together is a recipe for disaster.  Park it.  Dispatch doesn't like it?  Refer them to the Safety Department.","replyToPid":0}
 楼主| 发表于 2019-12-18 09:27:25 来自手机 | 显示全部楼层
706634 发表于 2019-12-15 18:22:11 I have no problem with wind or snow, but both together is a recipe for disaster.  Park it.  Dispatch doesn't like it?  Refer them to the Safety Department.
","text":"I did drive that day but where I live snow and wind is just what we deal with. like most of the places around here we have 2 seasons 1 is road work and the other is snow. I have been doing good so far and have been using all the tips everyone here gave me. Thank you everyone.","replyToPid":282660}
发表于 2019-12-19 15:12:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes you have 18 tires on the ground or snow your going to do better than you expect but respect it like its ice because some bridges will be dont use Jake's or retarded and lock in your differential  you'll see 4 wheelers in the ditch no biggie you know why ,there odiots but when you start seeing snow plows and big trucks in the ditch probably a good time to shut her down get a little rest needed or not","replyToPid":0}
发表于 2019-12-19 12:55:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t ride that brake driver. Take your time no load is worth more than your life. God bless ","replyToPid":0}
 楼主| 发表于 2019-12-11 23:32:42 来自手机 | 显示全部楼层
758476 发表于 2019-12-11 12:51:20 Slow and easy is good. Give yourself extra time to slow down to stop, increasing your following distance for you have time to stop.
","text":"Thank you for the help","replyToPid":279313}
 楼主| 发表于 2019-12-11 23:32:51 来自手机 | 显示全部楼层
705502 发表于 2019-12-11 13:06:26 Either slow-rolling or shut down.
","text":"Thank you for the help","replyToPid":279317}
 楼主| 发表于 2019-12-11 23:33:03 来自手机 | 显示全部楼层
859407 发表于 2019-12-11 13:11:42 No engine brakes, no cruise control and do not do anything abrupt (I.E. whipping the steering wheel, stabbing the brakes, etc)\n\nAnd do not drive beyond your comfort zone.  There is no shame in being passed by our super trucker buddies.
","text":"Thank you for the help","replyToPid":279322}
GMT+8, 2026-2-16 01:04 , Processed in 0.083246 second(s), 24 queries .
