查看: 337|回复: 4
Question
 楼主| 发表于 2019-12-11 05:33:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"Is there anything illegal about these airlines?  ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":960.0,\"name\":\"169981/8_1576013597_1576013597.jpg\",\"url\":\"\",\"width\":720.0}]","canComment":true,"externalShare":false}
发表于 2019-12-11 05:43:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes the air lines are touching the frame of the truck. Raise them up and you're good","replyToPid":0}
发表于 2019-12-11 17:41:09 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Looks ok, but had two different drivers come back once with warnings about the lines hanging to low and also chaffing causing wear to the lines. Just make sure they dont get caught on the frame."}
发表于 2019-12-11 21:57:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Exactly what the other 2 drivers said. Your lines cannot touch your frame. ","replyToPid":0}
发表于 2019-12-11 21:49:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"They are touching the frame. Can't touch anything","replyToPid":0}
GMT+8, 2026-2-16 06:30 , Processed in 0.079832 second(s), 24 queries .
