查看: 110|回复: 5
Manual to Automatic Transmission
 楼主| 发表于 2019-12-11 03:08:55 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can you give me some tips or what will I need to get used to?  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-22 21:08:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"my only advice is to run..... RUN! it's a trap! everybody with a good sound mental state knows that manual transmissions are better.","replyToPid":0}
发表于 2019-12-11 08:02:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"No shifter for resting your hand while driving... 😁","replyToPid":0}
发表于 2019-12-16 02:46:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get used to pressing an invisible clutch lol it is bound to happen until you get used to the fact that its n there anymore same with the shifter your bound to go for it when taking off lol other than that you’ll be good oh and HSA turn it off when backing up i find it a pain when you have to back up or pull away from a dock ","replyToPid":0}
发表于 2019-12-22 23:36:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"They have a \"hesitation\" when throttling from stop, especially in surface road commuter traffic. Some cannot down shift by manual over ride, one must \"jake\" and brake. Brakes wear out sooner.","replyToPid":0}
发表于 2019-12-23 02:34:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do you have a restriction on your license? That’s the first thing to worry about then it don’t matter. I prefer Manuel verses automatic but they both have pros and cons. It’s all about personal preference ","replyToPid":0}
GMT+8, 2026-4-17 10:13 , Processed in 0.101401 second(s), 24 queries .
