查看: 230|回复: 15
Did that uuy shimmied up that light pole to shovel snow off his trailer?
 楼主| 发表于 2019-12-10 04:48:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"I think he did. Do you think that's what happened?  ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":853.0,\"name\":\"228/Test%25206_1575924507_1575924507.jpg\",\"url\":\"\",\"width\":640.0}]","canComment":true}
发表于 2019-12-10 06:00:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"(Don't tell OSHA about this.)","replyToPid":0}
发表于 2019-12-10 09:23:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"My bad that’s the trees 😂😂😂😂😂","replyToPid":0}
发表于 2019-12-12 08:43:23 来自手机 | 显示全部楼层
848274 发表于 2019-12-10 22:30:51 climbed many light poles?🤔🤣🤣🤪
","text":"yeah I tried once when I was a teenager... Let's just say it didn't end well...","replyToPid":279065}
发表于 2019-12-10 09:23:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"So y’all don’t see the rope wrapped around him. ","replyToPid":0}
发表于 2019-12-10 10:03:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"that is incredibly considerate! I've seen sheets of snow the size of cars come flying off trailers before. it's a scary sight when you just pushing 4 wheels.","replyToPid":0}
发表于 2019-12-10 10:41:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"OSHA wants a safety harness if you go more than 5 ft off the ground.  I had a few customers that refused to allow me to get on my own flatbed (right at 5ft if you dont look at the hump) to tarp/untarp, where they were more than happy to do that work for me with scissor lifts or just a crew with harnesses, when I can get the job done faster when solo without safety equipment.  Working from 13 and a half feet on a fiberglass roof that has no traction when wet scares the 💩 out of me.","replyToPid":0}
发表于 2019-12-10 05:31:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"it looks like the light pole is pretty deep in those trees... probably not close enough to the trailer... Also, it's not so easy to climb a light pole","replyToPid":0}
 楼主| 发表于 2019-12-11 01:37:16 来自手机 | 显示全部楼层
848274 发表于 2019-12-09 21:05:49 doubtful.  probably has something between the tractor and trailer.
","text":"Just want to know what you guys think.","replyToPid":278262}
 楼主| 发表于 2019-12-11 01:37:26 来自手机 | 显示全部楼层
834825 发表于 2019-12-09 21:31:08 it looks like the light pole is pretty deep in those trees... probably not close enough to the trailer... Also, it's not so easy to climb a light pole
","text":"got it","replyToPid":278269}
 楼主| 发表于 2019-12-11 01:37:33 来自手机 | 显示全部楼层
705502 发表于 2019-12-09 22:00:30 (Don't tell OSHA about this.)
","text":"😂","replyToPid":278285}
GMT+8, 2026-2-16 09:37 , Processed in 0.067443 second(s), 24 queries .
