查看: 152|回复: 6
What's the worst dispatcher mishap that you have been involved in?
 楼主| 发表于 2019-12-9 05:09:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"Just asking for future reference. lol  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-12-9 09:03:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"was given BOL# and Trl# for a load going to Texas. Shipper had that load going to Idaho. Dispatch told me to take it to Texas. You sure? \"Dont question me.\" Took it to Texas. Then took it to Idaho after being called a moron in Texas.","replyToPid":0}
发表于 2019-12-9 08:41:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"I need a favor from ya.","replyToPid":0}
 楼主| 发表于 2019-12-10 01:36:19 来自手机 | 显示全部楼层
792133 发表于 2019-12-09 01:03:39 was given BOL# and Trl# for a load going to Texas. Shipper had that load going to Idaho. Dispatch told me to take it to Texas. You sure? \"Dont question me.\" Took it to Texas. Then took it to Idaho after being called a moron in Texas.
","text":"Woah","replyToPid":277757}
发表于 2019-12-9 10:00:23 来自手机 | 显示全部楼层
 楼主| 发表于 2019-12-10 01:36:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Worst line ever","replyToPid":277732}
 楼主| 发表于 2019-12-10 01:36:40 来自手机 | 显示全部楼层
649124 发表于 2019-12-09 02:00:23 ...Good ?!...First I have a very good DM...but,have had issues with after hrs crew!...list too long to make!...do take these bits of advice for sure...on your end to cover your behind!\n1.)always Ask,Ask, about your load...Time,Date,parking at p/u or Drop?\n2 )goggle the place so you always have an idea of where you'll be getting in thrue...the entrance to most commercial facilities is not for trucks!(even if you have a Truck GPS...it will just get you to the area...\n3.)if possible call the place yourself to get the most accurate information...and they may have better suggestions. \n4.)if you can...always text or use whatever you have on your truck...so,it is documented what they say,and what you said!on the phone anybody can say anything!\n4.)@nd when stuff still goes South!Well,its part of the grind!...
","text":"😶😔😩","replyToPid":277782}
GMT+8, 2026-4-17 11:36 , Processed in 0.198113 second(s), 24 queries .
