查看: 410|回复: 27
Is anyone have problems with the massages mine is not working🤔🤔🤔🤔🤔it doesn't let me see my massages👀😁
 楼主| 发表于 2019-12-8 20:43:16 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-12-8 20:58:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Are you getting this massage from me? Just massage me if you are, and I'll massage you back!","replyToPid":0}
发表于 2019-12-8 23:21:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"I want a massage","replyToPid":0}
发表于 2019-12-8 23:57:49 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Stay safe "}
发表于 2019-12-8 21:11:46 来自手机 | 显示全部楼层
706186 发表于 2019-12-08 13:01:43 yes on here i can see your message 👀😁but on the messenger😁
","text":"well, I got your message. I hope you get all the massages you need! 😊","replyToPid":277330}
 楼主| 发表于 2019-12-8 20:48:49 来自手机 | 显示全部楼层
44008 发表于 2019-12-08 12:45:23 Turn off your phone for 5 minutes,. And turn it back on ,. Fix my problem.
","text":"Ok let me try it😁thanks and GOOD morning God bless 👉🐈","replyToPid":277322}
发表于 2019-12-9 02:53:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"i just got a message it says why are you gay? Um no?","replyToPid":0}
发表于 2019-12-10 04:16:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"pretty sure you can just step out of your truck and ask for someone to massage you.  should get a pretty quick response.  lol check the spelling in your first post","replyToPid":0}
发表于 2019-12-10 04:05:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Whats up with the massages?","replyToPid":0}
发表于 2019-12-9 14:45:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"were you ever able to view your messages?","replyToPid":277842}
 楼主| 发表于 2019-12-8 23:43:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"🤦","replyToPid":0}
发表于 2019-12-8 20:45:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Turn off your phone for 5 minutes,. And turn it back on ,. Fix my problem.","replyToPid":0}
发表于 2019-12-8 20:50:33 来自手机 | 显示全部楼层
706186 发表于 2019-12-08 12:48:49 Ok let me try it😁thanks and GOOD morning God bless 👉🐈
","text":"Good morning to you too,.  Is working ","replyToPid":277323}
 楼主| 发表于 2019-12-8 20:53:37 来自手机 | 显示全部楼层
44008 发表于 2019-12-08 12:50:33 Good morning to you too,.  Is working
","text":"nope👀🤔🤔🤔👉🐈","replyToPid":277324}
发表于 2019-12-8 20:58:12 来自手机 | 显示全部楼层
706186 发表于 2019-12-08 12:53:37 nope👀🤔🤔🤔👉🐈
","text":"Since the last update, if I close the app it won’t let me do anything after I open it back up ","replyToPid":277325}
 楼主| 发表于 2019-12-8 21:00:42 来自手机 | 显示全部楼层
173189 发表于 2019-12-08 12:58:12 Since the last update, if I close the app it won’t let me do anything after I open it back up
","text":"yeah i did that to didn't work👀🤔","replyToPid":277327}
 楼主| 发表于 2019-12-8 21:01:43 来自手机 | 显示全部楼层
872479 发表于 2019-12-08 12:58:53 Are you getting this massage from me? Just massage me if you are, and I'll massage you back!
","text":"yes on here i can see your message 👀😁but on the messenger😁","replyToPid":277328}
GMT+8, 2026-4-19 10:04 , Processed in 0.096940 second(s), 24 queries .
