查看: 88|回复: 3
Truth
 楼主| 发表于 2019-12-7 04:26:08 来自手机 | 显示全部楼层 |阅读模式
{"text":"Trucking schools private or company owned you won’t learn a thing as you are just another monkey to put behind the wheel. Trainers for these companies don’t care about you and just care about extra money in the pocket. You can’t learn a thing if trainer is sleeping, on phone or running team. More then half of the class won’t make it to the road for failure to pass drug test or medical issues. The ones the do get into the truck half of them won’t make it as they never researched the job before taking it. You are alone out here away from everything and anything you ever knew. It’s demanding, stressful and more. Basically only the strong survive out here and if you lack common sense go work for McDonald’s. ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2020-4-20 09:46:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"straight up.","replyToPid":0}
发表于 2020-4-22 02:40:06 来自手机 | 显示全部楼层
945897 发表于 2020-04-21 01:49:47 Why don’t you tell us something we don’t already know. Cap’n obvious
","text":"It's called commentary, but it is futile to tell YOU something new because you know it all...","replyToPid":358586}
发表于 2020-4-22 02:41:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"There are so e excellent private schools whose reputations are held to a higher standard by \"pride\" integrity and industry professionalism.  Otherwise, acute observation padawan.","replyToPid":0}
GMT+8, 2026-4-16 18:50 , Processed in 0.092615 second(s), 23 queries .
