查看: 306|回复: 12
if sign says all truck MUST enter but i have green light, what should i do?
 楼主| 发表于 2019-12-6 14:04:46 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-12-6 16:27:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"go back to trucking school, then take the common sense class...... after that, enroll in advance steering wheel holder","replyToPid":0}
回复 支持 3 反对 5
发表于 2019-12-7 02:59:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"the green light means go into the way station... pull in front of the building, honk your horn and hold your papers out of the window to let them know that you're ready for your inspection","replyToPid":0}
发表于 2019-12-6 18:44:49 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"if your prepass  gives you the green light,  you ARE allowed to bypass the weigh station,  UNLESS you are under a permitted load.  Next question.  jay_usa2016: what's a permitted load?!?!"}
发表于 2019-12-6 18:37:07 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"If I see a green light I pass weigh station. Otherwise what's the point of the prepass. Been OTR 5 yrs and no issues."}
发表于 2019-12-6 14:45:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Use the sign that says \"Prepass vehicles follow in cab signal\", unless you are under a permitted load.  In otherwords, follow the green light.","replyToPid":0}
发表于 2019-12-6 18:45:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"if your prepass  gives you the green light,  you ARE allowed to bypass the weigh station,  UNLESS you are under a permitted load.  Next question. jay_usa2016  : what's a permitted load?!?!","replyToPid":0}
发表于 2019-12-7 00:58:26 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"..."}
发表于 2019-12-7 03:10:23 来自手机 | 显示全部楼层
834825 发表于 2019-12-06 18:59:23 the green light means go into the way station... pull in front of the building, honk your horn and hold your papers out of the window to let them know that you're ready for your inspection
","text":"🤣🤣🤣","replyToPid":276277}
发表于 2019-12-7 06:43:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't pay $35 a month to be given a green light and still pull in the weigh station. Even if the sign says truck must exit. if I get green light it's hammer time. see ya bye.","replyToPid":0}
GMT+8, 2026-4-17 10:13 , Processed in 0.104308 second(s), 24 queries .
