查看: 691|回复: 30
if I get bypass. but there is a sign saying "All Truck Must Stop When Flashing", N is flashing. what do I need to do?
 楼主| 发表于 2019-12-6 10:38:04 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1440.0,\"name\":\"\",\"url\":\"\",\"width\":1080.0}]","canComment":true}
发表于 2019-12-6 16:31:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"go back to trucking school, then take the common sense class...... after that, enroll in advance steering wheel holder","replyToPid":0}
回复 支持 3 反对 3
发表于 2019-12-6 10:55:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Usually there is also a sign that’ll say to either follow onboard signals or to follow lighted messages. ","replyToPid":0}
发表于 2019-12-6 10:52:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bypass. That sign is for Owner Operators with no Qualcomm or ELD. ","replyToPid":0}
发表于 2019-12-6 12:05:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve gotten green on prepass then sign lights up truck must exit so I say if in doubt pull into weigh station. Because even these two things contradict each other lol. ","replyToPid":0}
发表于 2019-12-6 13:07:53 来自手机 | 显示全部楼层
676962 发表于 2019-12-06 04:05:19 I’ve gotten green on prepass then sign lights up truck must exit so I say if in doubt pull into weigh station. Because even these two things contradict each other lol.
","text":"better is when you get the red light and get the pull in sign in and the weight station is gated closed.","replyToPid":275847}
发表于 2019-12-6 19:16:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"bypass. I leave the bypass up on my screen for a little bit afterwards just in case","replyToPid":0}
发表于 2019-12-7 06:46:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't pay $35 a month to be given a green light and still pull in the weigh station. Even if the sign says truck must exit. if I get green light it's hammer time. see ya bye.","replyToPid":0}
发表于 2019-12-6 18:55:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"There was a N flashing??? I've never in my 21 years of driving seen a N flashing!! You have a prepass for a reason,  you know, to ummm....PREPASS!! Did you think that thing was for only when the stations are closed?? If the weigh station sign says \"closed\" and your prepass gives you the red light, are you going to pull in??  To answer your question; if the station is open and your prepass gives you the green light you ARE allowed to bypass the weigh station! UNLESS you are under a permitted load.","replyToPid":0}
发表于 2019-12-6 11:02:22 来自手机 | 显示全部楼层
836312 发表于 2019-12-06 02:52:40 Bypass. That sign is for Owner Operators with no Qualcomm or ELD.
","text":"fuckingmint 👌 LMAO 😂","replyToPid":275773}
发表于 2019-12-6 10:53:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"according to the dot office when I address that question to a state officer's they reply with if you get s green on your by pass and it's green if you were to get pull aside then they have to let you go but if it's red then your fucked.","replyToPid":0}
发表于 2019-12-6 10:51:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bypass ","replyToPid":0}
发表于 2019-12-6 10:52:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Go on bye ","replyToPid":0}
发表于 2019-12-6 11:04:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"that only for LTL","replyToPid":0}
GMT+8, 2026-4-17 05:11 , Processed in 0.118043 second(s), 24 queries .
