查看: 273|回复: 21
hey guys and girls for the vets how is it to drive in snow and ice ive never done it im a rooky I need help
 楼主| 发表于 2019-12-6 05:54:02 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-12-6 06:15:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t do anything abrupt.  Triple your following distance and do not drive faster than you are comfortable.  Put your ego down.  There is no shame driving slower than the other trucks","replyToPid":0}
回复 支持 11 反对 0
发表于 2019-12-6 06:16:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"my advice? know when to shut it down. Especially on Ice. Drive during the day as much as possible. Dont use engine brakes or excessive braking on Ice and snow. Carry Chains. Make sure youre aware of temps dropping and use Anti gel in your fuel. Also when you drive in bad conditions and the temp is near freezing or below DO NOT SET YOUR TRAILER BRAKES when you park for your break. They ice together like theyre welded and you will be stuck in the morning. Those last 2 will save you a ton of time and money in bad weather condions when the service trucks are super bust robbing trucker blind. I myself was not in the military but I would like to thank you for your service. Good luck Newbie.","replyToPid":0}
发表于 2019-12-6 06:35:13 来自手机 | 显示全部楼层
695861 发表于 2019-12-05 22:16:30 my advice? know when to shut it down. Especially on Ice. Drive during the day as much as possible. Dont use engine brakes or excessive braking on Ice and snow. Carry Chains. Make sure youre aware of temps dropping and use Anti gel in your fuel. Also when you drive in bad conditions and the temp is near freezing or below DO NOT SET YOUR TRAILER BRAKES when you park for your break. They ice together like theyre welded and you will be stuck in the morning. Those last 2 will save you a ton of time and money in bad weather condions when the service trucks are super bust robbing trucker blind. I myself was not in the military but I would like to thank you for your service. Good luck Newbie.
","text":"I think he meant experienced truckers, but yes all of the above. if you have an automatic and things look sketchy set your speed 35 or less and hit that dif lock. if you get somewhere that requires chaining shut down and go to sleep!","replyToPid":275522}
发表于 2019-12-7 04:20:38 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"So, again to Clarify. \n\nYou are you running the rockies, or saying your a rookie??"}
发表于 2019-12-6 13:48:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Watch weather apps. Keep updated on DOT websites with closures and chain restrictions. Go slow and don’t let the big boys push you around. If you feel uncomfortable or unsure, shut it down and notify dispatch or rcvr. Keep it shiny side up 💕","replyToPid":0}
发表于 2019-12-6 09:56:41 来自手机 | 显示全部楼层
{"replyTo":"","text":" Don’t use your cruise control in snow or ice or slippery raining roads and drive a steady speed and not to fast so you can stop and don’t tail gate and slow down before you turn or exit off ","replyToPid":0}
 楼主| 发表于 2019-12-6 08:55:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well thanks guys for all the advest im taking it to heart just if you see a slower trucker thats probably me lol","replyToPid":0}
发表于 2019-12-7 04:02:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"put a penny between your buttocks and squeeze it till you stop driving. that's how I feel when driving in snow blizzards. cat litter and spray butter. use them.","replyToPid":0}
发表于 2019-12-6 11:08:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"just go slow on icy roads don't rush it or braking hard!!! I use my engine braking jb","replyToPid":0}
发表于 2019-12-6 07:58:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Are yyou saying that you are a new driver and you are getting ready to take a load Over the Rockies?please clarify","replyToPid":0}
发表于 2019-12-6 11:08:26 来自手机 | 显示全部楼层
626560 发表于 2019-12-05 23:58:01 Are yyou saying that you are a new driver and you are getting ready to take a load Over the Rockies?please clarify
","text":"lol","replyToPid":275624}
GMT+8, 2026-2-15 18:19 , Processed in 0.055807 second(s), 24 queries .
