查看: 556|回复: 19
to connect or not
 楼主| 发表于 2019-12-6 04:18:28 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm here to pick up a load, not feeling very secure a out hauling it due to how a tire looks. your opinion please. it's a 53 foot trailer and the rear outside tire has some chunks of tread missing along very edge almost on sidewall. would you connect?","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2592.0,\"name\":\"\",\"url\":\"\",\"width\":1944.0},{\"description\":\"\",\"height\":2592.0,\"name\":\"\",\"url\":\"\",\"width\":1944.0}]","canComment":true}
发表于 2019-12-6 06:35:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"send it!!!!! lolololol","replyToPid":0}
发表于 2019-12-6 08:20:33 来自手机 | 显示全部楼层
619820 发表于 2019-12-06 00:14:41 not a fake account just wanted confirmation on what I already thought but thanks for the negative thought
","text":"yet you needed confirmation on an illegal dangerous tire and you are a trucker ?  go bake a pie","replyToPid":275644}
 楼主| 发表于 2019-12-6 08:13:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"well pissed off the broker and shipper when I refused to connect to that load. but I wanted to survive another day","replyToPid":0}
发表于 2019-12-6 06:41:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"this is yet another fake account set up by trucker path..no real trucker needs to post pictures of this to ask that they should do .","replyToPid":0}
发表于 2019-12-6 04:42:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"go ahead and head out you deserve whatever happens for allowing that pos tire to get that bad.","replyToPid":0}
 楼主| 发表于 2019-12-7 04:11:35 来自手机 | 显示全部楼层
870093 发表于 2019-12-05 20:42:37 go ahead and head out you deserve whatever happens for allowing that pos tire to get that bad.
","text":"that wasnt my tire that was on a trailer that I was supposed to pick up but DID NOT connect too","replyToPid":275466}
发表于 2019-12-6 04:24:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Driver please get that tire changed, that tire is dangerous! Think safety, I wouldn't drive around the corner on that tire. \n\n I can assure you that tire will get you and your truck a trip to the back of the scale lot... as in Out  of Service.","replyToPid":0}
发表于 2019-12-6 13:16:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"depending on where I was and the nearest repair shop was I'd hook to it and head over there and screw the damn appointment time! or just call road service and have it replaced on site.","replyToPid":0}
 楼主| 发表于 2019-12-6 08:14:41 来自手机 | 显示全部楼层
870093 发表于 2019-12-05 22:41:43 this is yet another fake account set up by trucker path..no real trucker needs to post pictures of this to ask that they should do .
","text":"not a fake account just wanted confirmation on what I already thought but thanks for the negative thought","replyToPid":275548}
发表于 2019-12-6 04:37:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Change tire","replyToPid":0}
发表于 2019-12-6 06:22:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Its a recap. On newer ones theres rubber there hiding what you see there. when they get old you can see it alot better. That tire has seen its better days. consider yourself lucky it lasted this long and get rid of it. recaps are only around $200. Better to be safe and normally they tear the crap outta something else when the come apart.","replyToPid":0}
发表于 2019-12-6 07:11:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"not at all","replyToPid":0}
GMT+8, 2026-4-17 11:37 , Processed in 0.128608 second(s), 24 queries .
