查看: 198|回复: 16
What weight would you be concerned enough to go to a truckstop with a scale
 楼主| 发表于 2019-12-6 01:48:54 来自手机 | 显示全部楼层 |阅读模式
{"text":"and weigh it, same as above trailer 53' or 48' if this makes a difference?\n","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-12-6 02:36:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"30,000. Also, depends how its loaded.  When in doubt go scale.","replyToPid":0}
发表于 2019-12-6 04:24:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"I scale everything if I’m going anywhere near a weigh station. I don’t trust these shippers.","replyToPid":0}
发表于 2019-12-6 03:54:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"when anything is loaded into the trailer.","replyToPid":0}
发表于 2019-12-6 07:38:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Per axle or per axle GROUP?  20k is the limit in most states (when spread axle, or 17k per axle in tandem) with exceptions, such as Florida.\n\nI generally look at my air suspension pressure to get a general idea of how the load is balanced, along with the weights on the BOL, give me a good idea of the weight distribution.  When my ppw shows that I should be about 75k+ or deck shows greater than 55psi(overloaded drives) or less than 50psi on heavy loads (possibly overloaded trailer axles), is when I scale.","replyToPid":0}
发表于 2019-12-6 05:50:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"35,000 and higher","replyToPid":0}
发表于 2019-12-6 09:22:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"So long as you're not over gross, or really overweight on an axle group, you should be fine. I've been scaled at 12800 on my steers and almost 39000 on my drives and they let me go. I did have to blow them, though.\n\nYour results may vary.","replyToPid":0}
发表于 2019-12-7 10:53:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"46,500","replyToPid":0}
发表于 2019-12-6 18:23:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Anything above 34,000 with few pallets,  or 38,000 with many pallets unless I can eyeball the load, then it's a judgment call based on experience. \nThe only exception to this rule in my case is M&M Mars, I weigh all their chit!","replyToPid":0}
发表于 2019-12-6 09:11:25 来自手机 | 显示全部楼层
280160 发表于 2019-12-06 00:13:19 Depends on the load weight and my drive axle suspension load.\n\nA 60psi load is around 33.5k on my drives.  Weight on my drives when empty is around 12.5k so that means there is around 21k of the load weight on my drives.\n\nRemainder of load would be on my tandems which are 9.7k empty.
","text":"Yea, not all tractors are the same.  I had 34k on drives at 58psi, so I look at 55psi as my threshold to use a scale to make sure on my weights.","replyToPid":275643}
发表于 2019-12-6 08:13:19 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Depends on the load weight and my drive axle suspension load.\n\nA 60psi load is around 33.5k on my drives.  Weight on my drives when empty is around 12.5k so that means there is around 21k of the load weight on my drives.\n\nRemainder of load would be on my tandems which are 9.7k empty."}
发表于 2019-12-6 03:57:57 来自手机 | 显示全部楼层
850575 发表于 2019-12-05 18:36:59 30,000. Also, depends how its loaded.  When in doubt go scale.
","text":"I agree","replyToPid":275376}
发表于 2019-12-6 05:12:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"it depends...Florida for instance allows 44,000 per axle and ga. 37,340 Delaware 40k CT 36k CO. 40k south Carolina 39k Ri 44,000... if I were you I'd just go weigh at the cat scale and ask the closest coffee guzzling cigarette smoking old hand out there","replyToPid":0}
发表于 2019-12-6 07:41:31 来自手机 | 显示全部楼层
470402 发表于 2019-12-05 21:12:54 it depends...Florida for instance allows 44,000 per axle and ga. 37,340 Delaware 40k CT 36k CO. 40k south Carolina 39k Ri 44,000... if I were you I'd just go weigh at the cat scale and ask the closest coffee guzzling cigarette smoking old hand out there
","text":"Florida allows one axle to be at 44k, but gvw still has to be under 80k.","replyToPid":275476}
GMT+8, 2026-2-15 16:54 , Processed in 0.054856 second(s), 24 queries .
