查看: 163|回复: 11
How do you know if the price of a load is you are going to haul is reasonable?
 楼主| 发表于 2019-12-5 03:43:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"Are there websites where you can compare the prices?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-12-5 04:18:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"This is basic trucker knowledge that you should know before you step into a truck divide your mileage by the price to load pays and you’ll get your price per mile and I hope you know what a reasonable price per mile is that you need to be profitable","replyToPid":0}
发表于 2019-12-5 04:06:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"since you don't know the basic principles of business see if truckmiles.com will teach you something","replyToPid":0}
发表于 2019-12-5 03:45:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Start at figuring out your cost per mile to run.","replyToPid":0}
发表于 2019-12-5 10:08:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"🤣😂 definitely trolling","replyToPid":0}
发表于 2019-12-5 19:14:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"No websites use your brain and figure your cost and haul no cheap load if it’s cheap move on","replyToPid":0}
 楼主| 发表于 2019-12-8 02:30:06 来自手机 | 显示全部楼层
762776 发表于 2019-12-04 19:45:44 Start at figuring out your cost per mile to run.
","text":"Will do that. Thanks","replyToPid":274364}
 楼主| 发表于 2019-12-8 02:30:16 来自手机 | 显示全部楼层
682141 发表于 2019-12-04 20:06:51 since you don't know the basic principles of business see if truckmiles.com will teach you something
","text":"Will check that out","replyToPid":274411}
 楼主| 发表于 2019-12-8 02:30:25 来自手机 | 显示全部楼层
851115 发表于 2019-12-04 20:18:37 This is basic trucker knowledge that you should know before you step into a truck divide your mileage by the price to load pays and you’ll get your price per mile and I hope you know what a reasonable price per mile is that you need to be profitable
","text":"on it","replyToPid":274436}
 楼主| 发表于 2019-12-8 02:30:32 来自手机 | 显示全部楼层
854041 发表于 2019-12-05 02:08:45 🤣😂 definitely trolling
","text":"naaaah","replyToPid":274818}
GMT+8, 2026-2-15 17:55 , Processed in 0.080924 second(s), 24 queries .
