查看: 167|回复: 6
What would you do if you think that your codriver has a certain liking for you
 楼主| 发表于 2019-12-5 03:17:42 来自手机 | 显示全部楼层 |阅读模式
{"text":"Plot twist - you are both men  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-12-5 03:53:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"both of you get outta here and back on grindr","replyToPid":0}
回复 支持 6 反对 0
发表于 2019-12-5 03:46:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"In your case hit it.","replyToPid":0}
回复 支持 6 反对 0
发表于 2019-12-5 04:51:58 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Make certain dude understand that you are a pitcher and not a catcher.  Then IMMEDIATELY don a spiked French tickler with Carolina reaper lube sauce.\n\n*edit-  then climb in bunk and hand dude a ball gag and gimp mask."}
发表于 2019-12-5 10:10:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"why I drive solo!!! no problems can be created","replyToPid":0}
发表于 2019-12-5 03:43:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"point out the fact you have a 38 and are VERY quick reflexes","replyToPid":0}
发表于 2019-12-5 07:33:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"GTFOH!!!","replyToPid":0}
GMT+8, 2026-2-15 16:54 , Processed in 0.051155 second(s), 24 queries .
