查看: 154|回复: 2
Backing procedures
 楼主| 发表于 2019-12-4 06:16:43 来自手机 | 显示全部楼层 |阅读模式
{"text":"What is the correct etiquette for backing and waiting for someone to back up?\n4 way flashers, fly by the person backing, etc??","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-12-4 06:57:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"When someone is backing, try to fly behind them, then act like they are the arsehole when they get mad.","replyToPid":0}
发表于 2019-12-4 08:45:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you are the person backing letting everyone by before you start backing is proper. \n\nIf you are waiting for someone. You wait till you can get by without being in your way. \n\nAlso if you need to do a pull up yet there is room for trucks to get around you let them go by. Your are parking what’s the hurry. Your log is already using on duty time because you are under that 5 mph mark. That’s why sometimes you sit there for 4 min waiting for it to flip to on duty because you parked fast. Or if it takes you awhile you end up waiting only 2 min to flip or it flips while you are backing because it took that long to get into that spot. ","replyToPid":0}
GMT+8, 2026-4-17 13:14 , Processed in 0.070037 second(s), 24 queries .
