查看: 401|回复: 4
The mechanic in me...
 楼主| 发表于 2019-12-3 09:16:24 来自手机 | 显示全部楼层 |阅读模式
{"text":"So this fellow trucker pulls in and idling his truck for a while as if he was doing a regeneration cycle. I was out getting a brisk walk when all of a suddenly what sounds like a 12 gauge shotgun goes off. Dude bolts out and opens his hood. Now the driver had his phone paired to his Bluetooth head unit to which you can hear his conversations with his emergency repair line, which took awhile to get through as he was on hold for the longest of time. Whatever the issue, it seems the ECM diagnostics being reviewed from corporate support is unable to find an issue. After an hour they finally relent and sent out a technician.\n\nSo the mechanic in me is wondering what his issue could have been and what I could possibly learn from it since I'm still a rookie.\n\nLuckily my carrier isn't so large to afford hold music.😅","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1134.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0}]","canComment":true}
发表于 2019-12-3 20:08:42 来自手机 | 显示全部楼层
794377 发表于 2019-12-03 11:13:45 Vise grips would have fixed that
","text":"Yes. Wow. I can’t imagine paying $100/hour to some kid with his name on his shirt to fix that. ","replyToPid":272450}
 楼主| 发表于 2019-12-3 18:08:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Update: Apparently our fellow driver ruptured  a cab dampening air bag which caused him to be unable to maintain pressure throughout the system. I guess it's not possible to be prepared for everything.","replyToPid":0}
发表于 2019-12-4 10:56:56 来自手机 | 显示全部楼层
794377 发表于 2019-12-03 12:45:59 Pinch the air line off , send it down the road. When I build/rebuild a truck for myself one day, every single airbag and brake can is going to get a quarter turn valve in line, that way if you ever blo an air bag or brake can out on the road you can shut the air going to it off and drive it home
","text":"that is a good idea","replyToPid":272508}
发表于 2019-12-4 12:19:47 来自手机 | 显示全部楼层
","text":"Always carry 2 of them ","replyToPid":272450}
GMT+8, 2026-2-15 10:35 , Processed in 0.077300 second(s), 24 queries .
