查看: 275|回复: 13
Having trouble sleeping
 楼主| 发表于 2019-12-3 05:48:26 来自手机 | 显示全部楼层 |阅读模式
{"text":"What tips can you give someone who is having a hard time sleeping in a moving truck?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-12-3 20:59:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"quit team driving!  your splitting an already crappy rate.","replyToPid":0}
回复 支持 3 反对 2
发表于 2019-12-4 00:50:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Smoke some green","replyToPid":0}
发表于 2019-12-3 16:59:29 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"If you’re full-time team invest in a memory foam mattress. Put a body pillow behind you and in front of you. Take some form of sleep aid like melatonin. If you’re just in training try the pillow and sleep aid cause it’s only for a little while "}
发表于 2019-12-4 01:44:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yea definitely go solo as soon as you can. You'll notice a major difference in your sleep, mood, and motivation. There is no way to get sound sleep especially driving on some of these roads where it's like a rumble strip for miles on end.","replyToPid":0}
发表于 2019-12-4 01:50:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Pistachios.","replyToPid":0}
发表于 2019-12-4 03:52:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"put the phone down and close your eyes, use earplugs and make sure that it is as dark as possible","replyToPid":0}
发表于 2019-12-4 03:54:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://www.dailymail.co.uk/sciencetech/article-3067526/amp/Can-t-sleep-4-7-8-breathing-technique-claims-help-nod-60-SECONDS.html#aoh=15754027938384&referrer=https%3A%2F%2Fwww.google.com&amp_tf=From%20%251%24s","replyToPid":0}
发表于 2019-12-4 04:22:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"nyquil ear plugs","replyToPid":0}
发表于 2019-12-4 08:59:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don't worry. You'll get to a point that you'll miss so much sleep that as soon as you hit your bed, you'll knock the f*ck out. You'll get used to it.","replyToPid":0}
GMT+8, 2026-4-17 10:13 , Processed in 0.123357 second(s), 24 queries .
