查看: 152|回复: 0
Trucks Don’t Wreck Themselves
 楼主| 发表于 2019-12-2 19:17:11 来自手机 | 显示全部楼层 |阅读模式
{"text":"As I warm up my truck this AM I can’t help but reflect on the accident I covered Friday. As a newer driver myself we can all learn a lesson from this one. \n\nThis truck rolled completely over after spinning a 180. Conditions the night of were near white out and chains required. Trying to keep identifying material from photo. But it was not a swift driver as some of you may assume. \n\nThere were no chains involved in a chain required area that night. Obviously too fast for conditions and some driver panic resulted in this. No one including driver was hurt so this is a best case scenario for the driver but I can assure you they’re now unemployed. Don’t let this be you. Run safe and use your chains when needed. 30 minutes or less could have saved this driver a world of hurt. \n\nBe safe this winter and always error on the side of caution. ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":568.0,\"name\":\"\",\"url\":\"\",\"width\":756.0}]","canComment":true}
GMT+8, 2026-4-17 11:36 , Processed in 0.119026 second(s), 23 queries .
