查看: 122|回复: 3
South Texas Heat 🥵🥵🥵
 楼主| 发表于 2019-5-28 06:13:10 来自手机 | 显示全部楼层 |阅读模式
{"text":null,"videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0}]","canComment":true}
发表于 2019-5-28 07:50:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"TX!","replyToPid":0}
发表于 2019-5-28 09:01:23 来自手机 | 显示全部楼层
625878 发表于 2019-05-27 23:39:38 Dude it is hot, but what is actual temperature, you are idling and not moving. So you are getting a ton of heat from the block
","text":"I agree..it normally drops a few degrees when you start moving 👍","replyToPid":46590}
 楼主| 发表于 2019-5-28 22:39:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"I was only idling for about 25min. Was on my 30. \nHour east of El Paso. Was about 98ish. \nSure beats running the 80 most of last week. Lots of cold weather and snow still. \n","replyToPid":0}
GMT+8, 2026-4-17 11:20 , Processed in 0.078944 second(s), 23 queries .
