查看: 112|回复: 7
What are the ways tostay awake when your eyes wanna close?
 楼主| 发表于 2019-12-2 11:49:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"Any advice?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-12-2 14:05:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Jump onto your sleeper take 1 or 2 hours rest while getting your 30 min break too listen to a podcast or audio book stop somewhere walk a little in fresh air don’t drink coffe late in your 10 hour shift because then you can’t sleep get YouTube premium play your favorite videos in the background also don’t eat too much food ","replyToPid":0}
发表于 2019-12-2 13:36:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"tips1 as you drive put ur left hand on the airhorn and just keep on driving make sure to lower window down a lil bit.l.. p.s dose not work on volvos. tip2, bring a jump rope get out of truck and jump rope do pushups or succides untill ur heartbeats rasing. tip3. link ur phone to your radio via bluethoth or aux cable set it really loud and put 7 to 8 alarms to run every 30 seconds and dont snoozed them, p.s u can also go on youtube and put loud screaming noices and let it play on radio. tip 3 buy a pack of paquis hunted ghost pepper chips and eat one when u feel tired, tip4, set ur air to as cold as u can and drive with ur shirt of, and if all that fails thrm tip 5, pull over and sleep","replyToPid":0}
发表于 2019-12-2 13:49:47 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Get plenty of sleep, fresh air, and a little exercise and eat healthy and you won’t have a problem. Unless you’ve got something medically wrong the doc needs to sort out. "}
发表于 2019-12-2 13:39:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get sleep","replyToPid":0}
发表于 2019-12-3 15:12:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sh*t pull that big motherf*cker off the road sum where safe an park that b*tch an jump in the bak and get sum sleep!! You got a bed that follows you around all day use it!! No load is too hot no matter wat dispatch says, F*CK’EM!!","replyToPid":0}
发表于 2019-12-2 12:43:57 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"The best way is to pull your butt over and get some sleep bud, don’t be a danger to yourself or anybody else around "}
发表于 2019-12-2 13:30:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"plenty of advice brother dose ur truck have build in bluthtoth to the radio","replyToPid":0}
GMT+8, 2026-2-15 10:35 , Processed in 0.066311 second(s), 24 queries .
