查看: 213|回复: 10
30 minute break?
 楼主| 发表于 2019-12-1 16:25:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"A lot of you get mad at 30 minute break at fuel Island, but what if they are taking that break at 2am and no one at any of the fuel pumps and there is no parking?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-12-1 16:50:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Come on, common sense would tell you that is a different matter all together. If its rush hour and you're at the island drive on and park. If it's 2 a.m. and no one is around who is there to stop from making $$$? \n\nI understand Common sense isn't Common but sometimes just sometimes it has to be.","replyToPid":0}
回复 支持 10 反对 0
发表于 2019-12-3 09:09:52 来自手机 | 显示全部楼层
703174 发表于 2019-12-01 17:21:08 Doing 30 min break at 2am at fuel island is fine until someone miss every empty pump and pulls in behind you
","text":"and he will sit behind me until I finish my break for being a complete idiot. ✌","replyToPid":270349}
发表于 2019-12-2 01:21:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Doing 30 min break at 2am at fuel island is fine until someone miss every empty pump and pulls in behind you ","replyToPid":0}
发表于 2019-12-1 21:07:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"0200 = 2 a.m. = Ok, we all do it at that hour\n\n1400 = 2 p.m. = Not ok, only jerks  and a*s*s*wipes pull that nonsense","replyToPid":0}
发表于 2019-12-2 00:46:15 来自手机 | 显示全部楼层
659914 发表于 2019-12-01 12:43:36 You can also take you 10 hour break
","text":"🤔","replyToPid":270094}
发表于 2019-12-1 22:48:32 来自手机 | 显示全部楼层
","text":"I’m learning so much 🎓","replyToPid":270094}
发表于 2019-12-1 20:43:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can also take you 10 hour break ","replyToPid":0}
发表于 2019-12-1 17:24:17 来自手机 | 显示全部楼层
651936 发表于 2019-12-01 08:50:24 Come on, common sense would tell you that is a different matter all together. If its rush hour and you're at the island drive on and park. If it's 2 a.m. and no one is around who is there to stop from making $$$? \n\nI understand Common sense isn't Common but sometimes just sometimes it has to be.
","text":"it just has ti it just has to lol","replyToPid":269974}
发表于 2019-12-2 01:14:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"During busy times park on the ramp and walk to the truck stop. You’ll get a bit of needed exercise and not take up a parking spot. ","replyToPid":0}
发表于 2019-12-2 12:26:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"As long as you are honest about it and don’t count it as your fuel time ","replyToPid":0}
GMT+8, 2026-2-15 09:35 , Processed in 0.062071 second(s), 24 queries .
