查看: 222|回复: 9
low bridges
 楼主| 发表于 2019-12-1 15:59:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"does this app really give you touring avoiding low bridges?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-12-1 21:51:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"It doesn't matter.  The sign says 12' 2\"!!!!!!","replyToPid":0}
发表于 2019-12-1 16:51:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can use it as a guide but always have a Motor Carrier's Road Atlas close by.","replyToPid":0}
发表于 2019-12-1 20:57:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"commen sense and youll be fine.my garmin routes ne safe but some bridges are one or two inches taller.better go slow while driving under or the corner cAn snag bridge if you drive like a super trucker.ive seen trucks get stuck.","replyToPid":0}
发表于 2019-12-2 13:07:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"please get you a trucker  GPS and stay out the far left lane.","replyToPid":0}
发表于 2019-12-2 07:14:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Normally I’d troll you but buy a decent truck routing specific GPS, use that and commons sense to judge a base what you see with your own eyes. \n\n\nAlso get a paper map for emergencies like, you purchased the Friday it’s ten minutes till shift end GPS, \n\nso it starts spinning in a circle. Cause quality control was ready to go home. \nAnd didn’t send it back for calibration. \n\nAlso these apps depend on a cell signal. What happens if the last 5 miles to the receiver has no cell tower signal and you was suppose to turn on the first road cause \n\nIt’s a low bridge 2 miles ahead. You’d miss that cause there’s no signal. ","replyToPid":0}
发表于 2019-12-2 00:48:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Only as a reference. An updated atlas is your best choice on low clearances.","replyToPid":0}
发表于 2019-12-2 07:01:21 来自手机 | 显示全部楼层
794398 发表于 2019-12-01 12:57:05 commen sense and youll be fine.my garmin routes ne safe but some bridges are one or two inches taller.better go slow while driving under or the corner cAn snag bridge if you drive like a super trucker.ive seen trucks get stuck.
","text":"lolol common sense","replyToPid":270110}
发表于 2019-12-1 22:29:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Gotta be smart I use my GPS to my discretion. But usually you’ll get a big sign saying low bridge ","replyToPid":0}
发表于 2019-12-2 11:57:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Use a GPS as a tool, do not rely on them solely.  Get a Motor Carrier's Rand McNally, and read the signs and warnings.  If anything, try Google Streetview to read the signs before you get to a stop, to get an idea of what is ahead.","replyToPid":0}
GMT+8, 2026-4-17 11:37 , Processed in 0.108241 second(s), 24 queries .
