查看: 132|回复: 5
scales when to stop
 楼主| 发表于 2019-12-1 15:27:32 来自手机 | 显示全部楼层 |阅读模式
{"text":"wa state. truck gvwr. 13k f350.  ttailer flat bed gvwr 14k. load. jet skis 1400 lbs trailer weight total 7000 lbs non comm vehicle do i need to stop at scales or am i just in the way thank you in advance some said i had to scale ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-12-1 21:11:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Non commercial vehicle, not for hire. FHMCSA rules don't apply to you. Carry-on and have a safe trip!","replyToPid":0}
发表于 2019-12-2 09:56:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t go to CA. If you’re crawling down 395 in Nor Cal at 55 and a DOT cop sees you he WILL stop you and cite you for no DOT# and if you’re not licensed to be pulling that trailer (class A or at least J endorsement) you will be put OOS. They’ve also been picking on the barrel racers going thru Truckee. Really taking a bit outta crime they are!","replyToPid":0}
发表于 2019-12-2 00:50:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"If u don't have a USDOT number on both sides of the vehicle, u don't have to cross scales.","replyToPid":0}
发表于 2019-12-1 21:20:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"If there’s over night parking why not ","replyToPid":0}
 楼主| 发表于 2020-3-2 01:29:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"thanks","replyToPid":0}
GMT+8, 2026-2-15 07:35 , Processed in 0.067641 second(s), 24 queries .
