查看: 132|回复: 5
Boosting Your Immune System Tips!
 楼主| 发表于 2019-5-28 00:31:46 来自手机 | 显示全部楼层 |阅读模式
{"text":"Having an illness makes everything harder to do, whether it's getting out of bed or putting in a productive day's worth of work. Sometimes getting sick is the worst, especially if you are a truck driver. Sickness is inevitable and you just have to deal with it. However, prevention is always better than cure. With that, here are some tips to boost your immune system:\n\n\nStay Hydrated\nGetting a steady dose of water helps your body regulate and flush out anything that may potentially cause you to fall ill.\n\n\nGet Quality Sleep\nYour body needs sleep to rest and recuperate from the wear and tear you put on it during a given day, plus missing sleep makes the following day even harder on your body. \n\n\nEat healthily\nPutting too much sugar or meat on your body doesn't do you any good. Always plan for a balanced meal to make sure that your body is on top condition\n\n\nAny other tips? Share it with us in the comments!","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":720.0,\"name\":\"980/7_1558974700_1558974701.png\",\"url\":\"\",\"width\":720.0}]","canComment":true}
发表于 2019-5-28 01:36:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Vitamins","replyToPid":0}
发表于 2019-5-28 01:57:21 来自手机 | 显示全部楼层
662769 发表于 2019-05-27 17:40:31 How about checking on why I can not upload or change my profile image and address the troll.
","text":"Probably best not to add your photos anyway. Never know what that user might  try to attach to you that way. \nFake accounts can cause some real world issues. ","replyToPid":46049}
 楼主| 发表于 2019-5-28 02:00:33 来自手机 | 显示全部楼层
","text":"Hi BNT!\n\nThanks for raising this concern to us. As per the trolls, we are all working to make sure that they are issued the proper sanctions in order to make the community better. \n\nAs per your inquiry about the \"Profile Photo,\" we have already raised that concern to our technical team.\n\nThank you and have a great day!","replyToPid":46049}
发表于 2019-5-28 02:29:39 来自手机 | 显示全部楼层
665437 发表于 2019-05-27 17:47:15 Too much meat? Blasphemy!
","text":"Agreed","replyToPid":46058}
发表于 2019-5-28 01:47:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Too much meat? Blasphemy!","replyToPid":0}
GMT+8, 2026-3-21 14:53 , Processed in 0.062306 second(s), 24 queries .
