查看: 201|回复: 13
 楼主| 发表于 2019-5-27 23:57:42 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[]","canComment":false}
发表于 2019-5-28 00:42:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Picture comments?","replyToPid":0}
发表于 2019-5-28 08:11:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Multiple point routing would be nice instead of just point A-B it would be nice to have 3 to four points of routing ","replyToPid":0}
发表于 2019-5-28 01:43:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"trolls removal","replyToPid":0}
发表于 2019-5-28 00:14:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"A means of private messaging/inbox wouldn't be a bad idea either.","replyToPid":0}
发表于 2019-5-29 04:06:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"windy is a good app for that","replyToPid":0}
发表于 2019-5-28 02:40:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes. Ability to add pics to comments.","replyToPid":45970}
发表于 2019-5-28 02:46:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yeah, when you’re in map mode and you pick an object, say a scale house or the like. The map tells you how far away it is.  This app uses “air miles” which is a straight line, and is almost always wrong because roads are not straight. On very short distances it’s ok, but the further out ya go, the more wrong it is. ","replyToPid":46116}
发表于 2019-5-28 02:32:33 来自手机 | 显示全部楼层
643146 发表于 2019-05-27 17:56:07 Are you kidding? They can’t even get mileage right
","text":"mileage?","replyToPid":46069}
发表于 2019-5-28 01:56:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Are you kidding? They can’t even get mileage right","replyToPid":0}
发表于 2019-5-28 12:06:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yo those are some good inputs budd","replyToPid":0}
发表于 2019-5-28 01:44:28 来自手机 | 显示全部楼层
GMT+8, 2026-4-21 11:40 , Processed in 0.114213 second(s), 24 queries .
