查看: 159|回复: 6
Trip Advice
 楼主| 发表于 2019-12-1 03:32:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"so I'm headed to New Jersey from Jacksonville FL.\nHeavy Load. Any experienced drivers do you think going through Washingtons bypass and Boltimore is more convenient or more productive than taking the mountains on I-81 North. LMK would appreciate you","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-12-1 04:27:22 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"When are/did you leave Jax?if you left today, you should be ok going through DC & Baltimore without hitting too much traffic "}
发表于 2019-12-1 04:28:34 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"from Jackson to NJ just take 95 and deal with it. the traffic on weekends on 95 is fine!"}
发表于 2019-12-1 04:24:16 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"If you’re heavy I would avoid the mountains, if not for time, then at least for safety. Just remember to keep at least a truck length of following distance in front of you in heavy traffic. "}
 楼主| 发表于 2019-12-1 09:35:06 来自手机 | 显示全部楼层
731716 发表于 2019-11-30 20:27:22 When are/did you leave Jax?if you left today, you should be ok going through DC & Baltimore without hitting too much traffic
","text":"ok bet thx","replyToPid":269319}
 楼主| 发表于 2019-12-1 09:35:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"bett","replyToPid":0}
 楼主| 发表于 2019-12-1 09:36:04 来自手机 | 显示全部楼层
","text":"ok always do . hope it ain't snowing up there","replyToPid":269319}
GMT+8, 2026-4-18 12:46 , Processed in 0.075512 second(s), 24 queries .
