查看: 121|回复: 3
Anyway around Truckee?
 楼主| 发表于 2019-11-30 03:07:44 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm in Sparks, Nevada at the moment is there any way around 80 freeway to get to Sacramento?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-30 10:53:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes driver, 80e-95s-15s-58w-99n.. I may have forgot a interchange or two. take you a few days but dispatch will sure thank you with \n\n~Driver you missed your appt now we have to write you up.\n\nOr better yet, run your rig thru the Eldorado national forest.  Be sure to engage the 4 wheel drive otherwise CHP might have a issue. \n\nOn a serious note, park, rest and stay safe. No one gives a rats a** that you risked your life to run Donner pass in unsafe conditions. Choose wisely young Jedi...","replyToPid":0}
发表于 2019-11-30 07:26:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"not that's any safer","replyToPid":0}
发表于 2019-11-30 10:46:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nope. Have to wait it out unfortunately ","replyToPid":0}
GMT+8, 2026-2-15 06:48 , Processed in 0.067311 second(s), 24 queries .
