查看: 74|回复: 4
Thoughts on Magnet Heaters
 楼主| 发表于 2019-11-29 03:05:47 来自手机 | 显示全部楼层 |阅读模式
{"text":"Driving a 2006 Freightliner that starts a little rough even in 30 degree weather! (Block heater is working) Wondering if the magnetic oil pan heaters are worth trying out?  It's only gonna get colder in Michigan so trying to get a jump on things before its -10 degrees outside! Any thoughts appreciated!  Happy Thanksgiving everyone!","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-29 22:19:56 来自手机 | 显示全部楼层
794377 发表于 2019-11-28 19:15:07 Yes , heat rises, the oil pan is the lowest part of the engine, so you will be heating more of the engine than just the coolant
","text":"You need a Canadian winter starter pack. \n\nBlock heater \nIntake heater or glow plugs \nMagnet heater for your oil\nBattery blanket so they don’t freeze\n\nYup should be good \n","replyToPid":266868}
发表于 2019-11-29 22:27:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"yep that all works I am just on the other side of the peace bridge and the company I work for gets every truck that way.","replyToPid":0}
发表于 2019-11-29 23:52:04 来自手机 | 显示全部楼层
794377 发表于 2019-11-29 15:04:58 You missed one, spray ether
","text":"Make sure to use with glow plugs 😂😂😂😂","replyToPid":267923}
发表于 2019-11-30 10:10:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Anything there to prevent diesel from gelling? Unless you figured out how to suck jello through a fuel filter.","replyToPid":0}
GMT+8, 2026-2-15 06:48 , Processed in 0.066968 second(s), 24 queries .
