查看: 253|回复: 8
Speed
 楼主| 发表于 2019-11-28 01:59:23 来自手机 | 显示全部楼层 |阅读模式
{"text":"Someone know's someone who can boost my speed without letting my company know... This speed is too dangerous for me. too slow. takes years for me to pass. please help ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-28 02:58:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can’t because the minute they do a service on you’re truck they will know plus you’re speed is reported to the company so if you start maintaining for exp 68 miles per hour it’s going to flag the company that you are now doing this and they are gonna ask you to come in and fix it and if it happens again you are terminated . Not to mention company trucks are locked by the company . So good luck getting someone to unlock the ECM!   ","replyToPid":0}
发表于 2019-11-28 14:55:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can’t also your eld reports your speed to your company. ","replyToPid":0}
 楼主| 发表于 2019-11-28 02:48:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"2020 freightliner DT12 I think","replyToPid":0}
发表于 2019-11-28 02:41:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"What kind of truck? Engine ?","replyToPid":0}
发表于 2019-12-10 02:31:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Its possible. But risky for your job. And Expensive.","replyToPid":0}
发表于 2020-6-10 11:17:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"your company got to much control over your time and speed , leave it!!! or try to run under your own eld .  My comp. unlocked mine to 80 thru dealer of course., dosen t give a demn as long ther is no tiket , plus it helps me with eld if I need more h. whenever I need or feel like driving .. figure it out yourself what's best for you","replyToPid":0}
发表于 2020-6-11 00:52:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"U can add a feature called passsmart which lets u go 10 mph over your governed speed ","replyToPid":0}
发表于 2020-12-9 00:12:25 来自手机 | 显示全部楼层
884473 发表于 2020-06-10 16:52:57 U can add a feature called passsmart which lets u go 10 mph over your governed speed
","text":"How you do that ","replyToPid":382594}
GMT+8, 2026-2-9 06:24 , Processed in 0.067122 second(s), 24 queries .
