查看: 178|回复: 6
Just wondering
 楼主| 发表于 2019-11-28 01:08:43 来自手机 | 显示全部楼层 |阅读模式
{"text":"When the ELD records and shows \"unidentified driving\" can a company edit this in any way?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-28 15:00:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"You or your company cannot edit drive anymore. Only thing you do is dismiss unidentified driving off your log. Basically saying it wasn’t you. With eld all truck movement has to be recorded and accounted for. That is why you are suppose to log off going into the shop or home because it’s not you driving should someone move your truck faster then the 5mph. ","replyToPid":0}
发表于 2019-11-28 01:55:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes but when you edit it, it will also flag it as well ","replyToPid":0}
发表于 2019-11-29 01:32:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"You have to reject it and write a note on it saying “mechanic drove while in shop,” or something like that ","replyToPid":0}
发表于 2019-11-29 01:36:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"unidentified driving was put into place for Toronto. it's an oil field thing. no need to edit it. just adjust your start and end mileage. it's for when different people get in and out of the truck in short periods of time in the oil field. should have a special heading to go along with it.","replyToPid":0}
发表于 2019-11-29 10:55:25 来自手机 | 显示全部楼层
688983 发表于 2019-11-28 19:30:21 as soon as you hit 8 KPH / 5 MPH it automatically puts you in drive mode and cannot be edited.  so try to keep it no more than 6 KPH / 4 MPH to  be safe.
","text":"If nobody is logged in it shows unidentified driver","replyToPid":266885}
发表于 2019-11-29 17:24:40 来自手机 | 显示全部楼层
688983 发表于 2019-11-29 03:00:01 Do not accept time when you log in . As long as you logged out or it is not in your name you are good.\nMine shows unidentified driver also. Safety said do not worry about it.
","text":"Correct you just click it and reject it. ","replyToPid":267249}
GMT+8, 2026-4-17 14:51 , Processed in 0.071258 second(s), 25 queries .
