查看: 108|回复: 8
How cautious are you over high wind warnings?
 楼主| 发表于 2019-11-27 14:37:49 来自手机 | 显示全部楼层 |阅读模式
{"text":"looking for some experienced drivers on how seriously they take the warnings?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-27 20:16:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Depends on how much weight you have in the box. which direction the wind is blowing. \nI take it seriously even with 16yrs experience.","replyToPid":0}
发表于 2019-11-27 20:48:43 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"If you're loaded heavy - anything above 60 is parking it for more me.\n\nLight (0-20k) - \n35mph wind drive 55\n45 mph wind drive 45\n55 mpg wind drive 35\n\nif you cant keep it in your lane - park it\nif your dispatch has a problem with it, find a better job\n\nYou can slide your tandems back to decrease the whipping effect, there will be more evenly distributed wind hitting the trailer.\n\nAlso, older trailers or ones without the Side Skirt are much more dangerous all together in high winds, with these, lower your speed thresholds \n\nyall be safe"}
发表于 2019-11-27 15:18:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"I driven through some serious high winds especially through Phoenix Arizona I drove through a serious sandstorm everything was orange just got to keep them Wheels rolling although everybody's always looking for a place to park I remember that day only a few drivers are still out on the road","replyToPid":0}
发表于 2019-11-27 15:46:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"It depends on you and your experience, not me and mine. Reason being, a person with 30 years of experience knows what is truck is doing, and knows how to react, someone with 6 months doesn't have that just because they haven't been in that situation yet. It's like asking a driver how the weather was on a rainy day, could say not bad, then when you drive through it, it's like a hurricane","replyToPid":0}
发表于 2019-11-27 16:48:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"It depends on your load. Rule of thumb is anything under 15k, park it. It helps to slide your tandems back for stability, you want to leave some weight on them though. As stated, your the judge of your own ability.","replyToPid":0}
发表于 2019-11-27 17:38:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"If the winds come knockin, don't let the truck be rockin. Otherwise, you're f**ked.","replyToPid":0}
发表于 2019-11-27 20:34:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Extra careful on bridges. Going enpty is also not good choice ","replyToPid":0}
发表于 2019-11-28 02:47:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"take all warnings serious","replyToPid":0}
GMT+8, 2026-2-15 04:56 , Processed in 0.087327 second(s), 24 queries .
