查看: 242|回复: 4
HELP: Cascadia check engine lights
 楼主| 发表于 2019-1-24 20:34:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"Driving my 2009 Cascadia DD15 from San Francisco to Seattle.Currently in Seattle, Can I drive back to CA with this?the check engine light came on The check engine light and engine lightComes on then turns off after a couple minutes. Every 15-30 min.All fluids, oil,gauge pressures are good.The Fan was also coming on randomly, ANY ADVICE, help, hints APPRECIATE! Thanks","pics":"[]","canComment":true}
发表于 2019-3-5 06:21:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"What code is on the dash?","replyToPid":0}
发表于 2019-3-5 06:11:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"When you have a check engine light can you include the codes. We have  no idea what you are referring to when you say a check engine light is on. The codes narrowed us down to specific problems.","replyToPid":0}
发表于 2019-3-5 06:21:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"The only thing I can think of is your coolant level sensor may need to be changed out. You can use a paperclip as a quick fix to plug into the wire where the sensor plugs into. Do it until you can get somewhere to have it fixed so you're not stranded on the road.","replyToPid":0}
发表于 2019-5-21 11:18:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"that does souns like a coolant temp sensor.  I did the paper clip trick twice with my 2010. To get to a shop..","replyToPid":0}
GMT+8, 2026-4-17 06:23 , Processed in 0.081702 second(s), 24 queries .
