查看: 397|回复: 8
T880 Engine fan wont shut off and its 36 degrees out!
 楼主| 发表于 2019-1-24 20:27:31 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hello, I got a 18 T880 and the engine fan wont kick off along with 2 engine lights... I go in the cluster, and it says no warnings or faults.... before I take it to the dealer and lose the truck for days, is their a quick fix to this? T.I.A","pics":"[]","canComment":true}
发表于 2019-4-15 09:13:25 来自手机 | 显示全部楼层
184676 发表于 2019-04-14 23:27:22 ck the air line going to the clutch break on fan.
","text":"winner winner, had the exact same problem with a '14 589 Pete, only time the fan shut off was with the AC off","replyToPid":13923}
发表于 2019-4-6 00:27:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"could be coolent senser","replyToPid":0}
发表于 2019-4-15 07:27:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"ck the air line going to the clutch break on fan.","replyToPid":0}
发表于 2019-5-1 11:35:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"My t6 runs ac if the defrost is on... could be the same with the t880","replyToPid":0}
发表于 2019-8-7 07:41:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"chek the fan clutch fuse, is on the owners manual","replyToPid":0}
发表于 2019-9-28 00:49:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"check the solenoid","replyToPid":0}
发表于 2019-9-28 00:50:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"check the solenoid and wires going to it","replyToPid":0}
发表于 2019-10-25 15:14:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"air hose going to fan clutch may be leaking, put air into the fan clutch and make sure that the air hose is secured","replyToPid":0}
GMT+8, 2026-3-21 06:09 , Processed in 0.096759 second(s), 24 queries .
