查看: 200|回复: 7
How did that happen anyways?
 楼主| 发表于 2019-11-27 04:12:42 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can you tell me?  ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":960.0,\"name\":\"176241/17_1574799159_1574799159.jpg\",\"url\":\"\",\"width\":540.0}]","canComment":true}
发表于 2019-11-27 06:21:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Inner studs to short for aluminum wheels. Hollow putter carrying all the weight.  Change inners out to longer studs. ","replyToPid":0}
发表于 2019-11-27 05:02:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not paying attention that’s how and not doing your pre and post trip ","replyToPid":0}
发表于 2019-11-28 02:45:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"slid his a$s too tight","replyToPid":0}
发表于 2019-11-27 22:58:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Your nuts got loose and allowed a wobble that caused the studs to break ","replyToPid":0}
发表于 2019-11-27 22:40:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"wtf","replyToPid":0}
发表于 2019-11-27 23:00:19 来自手机 | 显示全部楼层
173189 发表于 2019-11-27 14:58:27 Your nuts got loose and allowed a wobble that caused the studs to break
","text":"You can usually feel it 10000 miles before it gets that bad if you pay attention ","replyToPid":265221}
发表于 2019-11-27 23:27:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Like one said already, loose nuts. There has to be a proper amount of torque put all the way around. If one gets loose the rest will follow. Seen it happen on small and big trucks with aluminum wheels. ","replyToPid":0}
GMT+8, 2026-2-15 00:40 , Processed in 0.078705 second(s), 24 queries .
