查看: 196|回复: 9
How often do you change tires?
 楼主| 发表于 2019-11-27 03:28:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"Just wondering.  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-27 04:48:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"The truck ones? Me? Never... I have a mechanic do it....🥴🥴🥴🥴","replyToPid":0}
发表于 2019-11-27 23:14:00 来自手机 | 显示全部楼层
89586 发表于 2019-11-27 14:28:29 I’m at 160K on my drive tires now and still going.
","text":"same here bud","replyToPid":265187}
发表于 2019-12-1 02:31:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Run them down to the air ","replyToPid":0}
发表于 2019-11-27 15:53:17 来自手机 | 显示全部楼层
255377 发表于 2019-11-26 23:05:46 Steers at 4/32ds and all the others at 2/32nds.  Tire life varies by design and use and maintenance. Deep lug drive tires can last over 3 years where steer and trailer tires about 1.5 years roughly. I use Michelin’s exclusively but there are other good brands as well.
","text":"how many miles do you get out of your drive tires?","replyToPid":264033}
发表于 2019-11-27 07:05:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Steers at 4/32ds and all the others at 2/32nds.  Tire life varies by design and use and maintenance. Deep lug drive tires can last over 3 years where steer and trailer tires about 1.5 years roughly. I use Michelin’s exclusively but there are other good brands as well. ","replyToPid":0}
发表于 2019-11-27 16:39:50 来自手机 | 显示全部楼层
658864 发表于 2019-11-26 20:48:48 The truck ones? Me? Never... I have a mechanic do it....🥴🥴🥴🥴
","text":"😂😂😂","replyToPid":263909}
发表于 2019-11-27 22:28:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m at 160K on my drive tires now and still going. ","replyToPid":0}
发表于 2019-11-29 01:29:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"when thay wear out or blow out","replyToPid":0}
发表于 2019-11-29 19:15:47 来自手机 | 显示全部楼层
728761 发表于 2019-11-27 07:53:17 how many miles do you get out of your drive tires?
","text":"400k give or take with wide based singles, xdn2 Michelin. ","replyToPid":264925}
GMT+8, 2026-4-17 11:36 , Processed in 0.168738 second(s), 24 queries .
