查看: 131|回复: 6
Tried Trucker Path GPS?
 楼主| 发表于 2019-11-27 00:30:00 来自手机 | 显示全部楼层 |阅读模式
{"text":"Who has used this? Share the pros & cons please. I want to throw out our Garmin trucker gps many times a day! please share! thanks y'all! ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-27 03:04:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don’t recommend relying on just one device or service for real time truck routing as none of them are perfect. But I’ve used the TP routing and it’s worked fine for me, but you need to find WiFi somewhere and download your maps onto your device so you can have GPS routing when you don’t have a phone signal. I use a combination of Navigo on the Qualcomm, Rand McNally truck GPS, Trucker Path, and Truck Map for iPhone. Occasionally I’ll crack open the atlas to learn about the areas/routes I’m less familiar with. ","replyToPid":0}
发表于 2019-11-27 09:58:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"I trust my analog gps , Aka an atlas.","replyToPid":0}
发表于 2019-11-27 06:11:41 来自手机 | 显示全部楼层
705502 发表于 2019-11-26 21:28:58 (U sure got a lot of tech on your hands. How much did it cost ya?) 🤔
","text":"It sounds like a lot, but it’s mostly apps on my phone and a Rand McNally TND gps. I only use the Qualcomm my carrier uses to see which side of the road the customer is on, the Qualcomm shows a geo fence around the customer’s property. ","replyToPid":263938}
发表于 2019-11-27 05:28:58 来自手机 | 显示全部楼层
497499 发表于 2019-11-26 19:04:13 I don’t recommend relying on just one device or service for real time truck routing as none of them are perfect. But I’ve used the TP routing and it’s worked fine for me, but you need to find WiFi somewhere and download your maps onto your device so you can have GPS routing when you don’t have a phone signal. I use a combination of Navigo on the Qualcomm, Rand McNally truck GPS, Trucker Path, and Truck Map for iPhone. Occasionally I’ll crack open the atlas to learn about the areas/routes I’m less familiar with.
","text":"(U sure got a lot of tech on your hands. How much did it cost ya?) 🤔","replyToPid":263756}
发表于 2019-11-27 06:44:05 来自手机 | 显示全部楼层
497499 发表于 2019-11-26 22:11:41 It sounds like a lot, but it’s mostly apps on my phone and a Rand McNally TND gps. I only use the Qualcomm my carrier uses to see which side of the road the customer is on, the Qualcomm shows a geo fence around the customer’s property.
","text":"Sounds about right. \n\nNeed to tell my company to get map updates. The ones they're using can't cut it no more (a la 2010).","replyToPid":263970}
发表于 2021-2-26 09:18:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"just started using it last Friday it was great. today it put me in the Bronx, NY and I should have been going to Long Island. UGH. it took me 2.5hrs to find my way out after the police had to stop traffic for me","replyToPid":0}
GMT+8, 2026-2-10 21:02 , Processed in 0.098134 second(s), 25 queries .
