查看: 349|回复: 16
Remove speed limiter?
 楼主| 发表于 2019-5-26 09:05:22 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’m a Swift Owner Operator with a 2019 T680. Anyone know of someone or someplace that is willing and/or capable of removing my limiter?\n\nOn my 2016 I had someone remove the ECU password and let me mess with some parameters, but that person isn’t available to me anymore.\n\nCummins X15 efficiency engine.  \n\nAll help is appreciated.","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-26 14:05:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you are an owner operator take it to KW. They will set it at whatever you want. ","replyToPid":0}
发表于 2019-5-26 14:03:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yeah your first mistake was signing a lease with swift lol ","replyToPid":0}
发表于 2019-5-26 10:33:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"My advice to you is run far far away from swift asap ","replyToPid":0}
发表于 2019-7-9 12:28:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’d say you’re looking for an independent shop with a “bi-directional” scanner. I would tell them (only if they ask) that you’re an owner / operator leased to Swift. Repercussions are on you if Swift gets pissed about it 😇","replyToPid":0}
发表于 2019-5-27 05:46:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"if u already have done it once why r u on here asking how to do dont mank since","replyToPid":0}
 楼主| 发表于 2019-5-27 00:19:18 来自手机 | 显示全部楼层
647598 发表于 2019-05-26 02:33:06 My advice to you is run far far away from swift asap
","text":"They’re actually not that bad. A good DM, good route, and good team driver and we do really good ","replyToPid":44512}
发表于 2019-5-26 12:51:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"dont no for sure but diesel doctor in effingham, il does computer work might be wofth a call","replyToPid":0}
发表于 2019-5-26 13:07:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Might need a Cummins program, hook up to a laptop. .. \nOr get a Cummins “Programmer” \n    I am only speculating, I need a specialized International programmer in order to even scan engine codes 🤦‍♂️","replyToPid":0}
发表于 2019-5-26 13:09:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Might need a Cummins program, tether to a laptop. .. \nOr get a Cummins “Programmer” \n    I am only speculating, I need a specialized International programmer in order to even scan engine codes 🤦‍♂️","replyToPid":0}
 楼主| 发表于 2019-5-27 00:00:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Its against Swift Policy to mess with any of that. Since Swift still technically owns the truck KW is afraid of getting in trouble. ","replyToPid":0}
 楼主| 发表于 2019-5-27 00:02:28 来自手机 | 显示全部楼层
553636 发表于 2019-05-26 05:09:34 Might need a Cummins program, tether to a laptop. .. \nOr get a Cummins “Programmer” \n    I am only speculating, I need a specialized International programmer in order to even scan engine codes 🤦‍♂️
","text":"I have access to some software, but I still need the password bypassed","replyToPid":44569}
GMT+8, 2026-3-21 15:14 , Processed in 0.070145 second(s), 24 queries .
