查看: 163|回复: 8
How do you stay in the business?
 楼主| 发表于 2019-11-26 02:48:07 来自手机 | 显示全部楼层 |阅读模式
{"text":"We often see a lot of small companies closing because of bankruptcy. What would you advice new owner operators to make sure that stay in the business and still have a good ROI?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-26 03:43:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"1. Dont be stupid, \n2. drive slower better fuel mileage, \n3. avoid sharp turns or u turns that decreases tire life, \n4. maintain tire pressure, \n5. preventive maintenance, \n6. dont believe the \"get a real truck\"B.S. Get a light, aerodynamic truck with an automatic, \n7. find a good broker. \n8. Stay out as long as possible\n9. Eat healthy, quit smoking, exercise","replyToPid":0}
回复 支持 4 反对 1
发表于 2019-11-26 22:41:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"1 simple thing don’t take a load for under 3 dollars a mile when you do it screws everyone else , brokers are getting rich and don’t do 💩","replyToPid":0}
发表于 2019-11-26 17:49:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"The biggest thing you can do to be successful is find a contract that pays well AFTER expenses. All the numbers and advice you get don’t mean anything. What are you keeping in a day? A week? If the answer is under 2000, you need to work on profitability. If you make over 4000 a week net then you’re probably a liar","replyToPid":0}
发表于 2019-11-26 23:32:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t over reach and try to grow to quick. You can make a great life for yourself and family with smart loads and a single truck operation. I myself run 3 weeks out and home for a week. Find the right market where you are at Whether it’s Refer. Dry van. Hopper. Flatbed. See where the industry is biggest and run that until it changes. I myself bought a hopper and I could not be any happier. Unbelievably great money. Find your lane and run hard. ","replyToPid":0}
发表于 2019-11-26 18:29:52 来自手机 | 显示全部楼层
210904 发表于 2019-11-25 19:43:22 1. Dont be stupid, \n2. drive slower better fuel mileage, \n3. avoid sharp turns or u turns that decreases tire life, \n4. maintain tire pressure, \n5. preventive maintenance, \n6. dont believe the \"get a real truck\"B.S. Get a light, aerodynamic truck with an automatic, \n7. find a good broker. \n8. Stay out as long as possible\n9. Eat healthy, quit smoking, exercise
","text":"Very very good advice right there. ","replyToPid":262687}
 楼主| 发表于 2019-11-27 01:33:36 来自手机 | 显示全部楼层
","text":"Thanks for this.","replyToPid":262687}
 楼主| 发表于 2019-11-27 01:33:47 来自手机 | 显示全部楼层
255377 发表于 2019-11-26 09:49:06 The biggest thing you can do to be successful is find a contract that pays well AFTER expenses. All the numbers and advice you get don’t mean anything. What are you keeping in a day? A week? If the answer is under 2000, you need to work on profitability. If you make over 4000 a week net then you’re probably a liar
","text":"Got it","replyToPid":263339}
 楼主| 发表于 2019-11-27 01:33:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks for all your input guys!","replyToPid":0}
GMT+8, 2026-4-18 12:28 , Processed in 0.081005 second(s), 24 queries .
