查看: 638|回复: 19
2017 kenworth sleeper heat problems 😡
 楼主| 发表于 2019-11-25 08:07:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"How do I keep my heat running in the sleeper when the truck is off?Someone please send a link or help its cold as hell out here.Thanks","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-11-25 09:12:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Releasing your tractor brakes doesn't always work. I had a kenworth and the company knew the trick and somehow they did something where it would still shut off after so long. Hopefully it works for you. My first 2 months out of school I had a peterbuilt and my bunk header wouldn't run for more then 2 to 4 hours. Took to shop they said it worked, well it didn't. So instead of spending more time in the shop I bought more blankets. Froze but kept making money and I won't do it again. That's why I'm o/o. Good luck driver.","replyToPid":0}
发表于 2019-11-25 11:10:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you Need I foward the FMSCA rules on sleeper berth, take it to your companies saftey Deptartment and if they still argue that you are not allowed to Idle, find another Job where your treated like a Professional truck driver that can make your own decisions.","replyToPid":0}
发表于 2019-11-25 11:05:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Another trick to bypass the auto cut off is to open the hood. There is a switch that activates when the hood is open so the mechanics can idle the truck as long as they need to.","replyToPid":0}
 楼主| 发表于 2019-11-25 08:43:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"thanks bro,im going to try it now,im freezing","replyToPid":0}
发表于 2019-11-26 20:39:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Can't say much since mine is a year older but if possible, slightly press the accelerate pedal, & set the cruise control. It should relieved any idle cutoff procedure on the truck. \n\nAnd should u drive in areas that's well below freezing, get some cardboard & zip ties & restrict the air flow going through the radiator. It'll help retain heat while you're driving.","replyToPid":263317}
发表于 2019-11-25 11:05:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Either that or check for a engine overide switch to prevent shut down? pull the relay?  \n\nFind a brick and put in on the fuel pedal to get those rpms up and maybe that will prevent shutdown.","replyToPid":0}
发表于 2019-11-25 09:19:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"thats what i do in my t680 to leave truck on only thing with pulling trailer brakes in the cold is it can lock the trailer brakes.","replyToPid":0}
发表于 2019-11-25 11:02:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Driver, does it have a idle up/cruise switch? If so, hit it, idle the truck up 1000 rpms to and burn that fuel... \n\nBurn baby burn!!!","replyToPid":0}
 楼主| 发表于 2019-11-30 19:14:46 来自手机 | 显示全部楼层
255590 发表于 2019-11-29 02:31:05 Hey driver, were you able to figure out a solution to keep your bunk heater working?
","text":"yea I figured it out to were it blows out a vent under my bunk.thank you all...","replyToPid":267223}
发表于 2019-11-25 09:37:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"I usually have to turn my key into the back position or on position to keep my bunk heater going. if I turn the key into off, the bunk heater will shut off after a few moments. ive got a 2020 freightliner but I hope that helps.","replyToPid":0}
发表于 2019-11-25 15:41:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"My pleasure. Yea they definitely do. Be safe & warm out there 💙","replyToPid":0}
GMT+8, 2026-3-21 04:35 , Processed in 0.130721 second(s), 24 queries .
